Passenger seat stuck? |
scallyk9 |
Feb 22 2017, 07:32 PM
Member Group: Members Posts: 322 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
Well, this is a new one for me and I can't find a solution in search regarding my new to me '74 914 LE. The driver's side track release works fine and I can move the seat fore and aft easily but the Passenger seat seems to be welded to the rail.
The handle is intact and I can pull it up or down, verified with a flashlight. Unfortunately it is stuck in the furthest aft position so as to obscure access from the rear. Could it be a rust problem? Or possibly is the spring missing. Does anyone know of a technique or trick to get it to release? No I really don't want to go in by cutting the bottom of the floor pan! |
Rand |
Feb 23 2017, 05:57 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
A long flat screwdriver should work. You don't need to pry up with the screwdriver, just slide it in under the rail. It doesn't take much to release. Maybe it is a rusty/stuck rail situation? Maybe try soaking the rails best you can with a penetrating lubricant and repeat? Maybe slip a plank behind the seat to pry against the firewall while the release is loose to see if a little extra pressure will help it move?
Lo-Fi Version | Time is now: 17th May 2024 - 05:49 PM |
