Changing US spec indicators to Euro style |
cal914 |
Feb 23 2017, 08:43 AM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
I'm converting our side lights to Euro style with the indicator on the bottom , I've got the parts to do this but don't know how to do it .There's 2 wires 1 longer than the other could some one give me an idea as to where they go
Thanks |
jmill |
Feb 23 2017, 10:27 AM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Search is your friend. (IMG:style_emoticons/default/cheer.gif)
I did a search and a ton of threads popped up. I'm not sure exactly what you need so you can bomb through them and find what you're looking for. I typed in "Euro indicator" and then clicked "Titles only" Maybe this? http://www.914world.com/bbs2/index.php?sho...=euro+indicator |
porschetub |
Feb 23 2017, 12:36 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I'm converting our side lights to Euro style with the indicator on the bottom , I've got the parts to do this but don't know how to do it .There's 2 wires 1 longer than the other could some one give me an idea as to where they go Thanks What parts or kit do you have ?,the long wire usually piggybacks on to the indicator connection of the upper dual filament lamp,if you have the plastic lamp holders the second short wire with go to earth (ground). I ditched my plastic bodied ones due to poor performance and purchased handmade metal ones from member martin baker,really well made,these don't have an earth connection as they get it from the light body. |
coupelover |
Feb 23 2017, 01:30 PM
Newbie Group: Members Posts: 21 Joined: 25-September 14 From: Atlanta Member No.: 17,952 Region Association: South East States |
I just converted to euro front signals. The long wire gets added to the ground plug on the back of the socket. Then find out which of the two remaining plugs controls the parking light (the other plug is the turn signal). Disconnect that from the back socket (since you don't want the top bulb to operate in that mode) and connect that wire directly to the short wire of the new bulb. I like the metal holder, better than the plastic ones I use.
Lo-Fi Version | Time is now: 5th May 2024 - 05:25 AM |
