Bad Vibrations, front end, steering vibration, comes and goes-causes? |
DRPHIL914 |
Feb 23 2017, 10:46 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
so I know the most obvious is a possible wheel balance issue and ill start there, - but here is what makes me thinks its not that- its at about same speed or close, between 60 and 70- goes away sometimes if going same speed but going around a corner etc- could be linkage? -
whats new- the whole front end with in last 2 years except the shock inserts. - 5 lug hubs new bearings last year with new A-arms and bushings and turbo tie rods, front end was balance and and aligned by professional shop(bob woodman tires) that is a 911 race shop too- turbo tie rods were installed by Georgie- 40+years working on Porsche's recently retired from HHI Porsche forced retirement at 70- SO - maybe check tire balance first I suppose? ths shocks feel fine but I don't know how old they are- all bushings etc were new with in 2 years- Thanks, Phil PS - how hard is it to put new inserts in front and do I have to re-align afterward?? |
Keith914 |
Feb 23 2017, 10:51 AM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
so I know the most obvious is a possible wheel balance issue and ill start there, - but here is what makes me thinks its not that- its at about same speed or close, between 60 and 70- goes away sometimes if going same speed but going around a corner etc- could be linkage? - whats new- the whole front end with in last 2 years except the shock inserts. - 5 lug hubs new bearings last year with new A-arms and bushings and turbo tie rods, front end was balance and and aligned by professional shop(bob woodman tires) that is a 911 race shop too- turbo tie rods were installed by Georgie- 40+years working on Porsche's recently retired from HHI Porsche forced retirement at 70- SO - maybe check tire balance first I suppose? ths shocks feel fine but I don't know how old they are- all bushings etc were new with in 2 years- Thanks, Phil PS - how hard is it to put new inserts in front and do I have to re-align afterward?? Typical symptom of poor wheel/tire balance, and less likely failing tire side wall. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:30 AM |
