Bad Vibrations, front end, steering vibration, comes and goes-causes? |
DRPHIL914 |
Feb 23 2017, 10:46 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
so I know the most obvious is a possible wheel balance issue and ill start there, - but here is what makes me thinks its not that- its at about same speed or close, between 60 and 70- goes away sometimes if going same speed but going around a corner etc- could be linkage? -
whats new- the whole front end with in last 2 years except the shock inserts. - 5 lug hubs new bearings last year with new A-arms and bushings and turbo tie rods, front end was balance and and aligned by professional shop(bob woodman tires) that is a 911 race shop too- turbo tie rods were installed by Georgie- 40+years working on Porsche's recently retired from HHI Porsche forced retirement at 70- SO - maybe check tire balance first I suppose? ths shocks feel fine but I don't know how old they are- all bushings etc were new with in 2 years- Thanks, Phil PS - how hard is it to put new inserts in front and do I have to re-align afterward?? |
DRPHIL914 |
Feb 23 2017, 04:46 PM
Better vibrations! Rebalance today- static and dynamic done in front tires and vibration at 60-65 is gone, just a bit at 70, so next week I wil take it over and have them do the rear -
Oh and a change in the CHT has given me a much better idle and no hesitation or loping once hot- it was cutting out so now after an hour drive none but we'll see after a few more drives- |
struckn |
Feb 23 2017, 06:06 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
Better vibrations! Rebalance today- static and dynamic done in front tires and vibration at 60-65 is gone, just a bit at 70, so next week I wil take it over and have them do the rear - Oh and a change in the CHT has given me a much better idle and no hesitation or loping once hot- it was cutting out so now after an hour drive none but we'll see after a few more drives- Sounds like you got it under control. I was going to suggest you swap front and rear tires to see if the vibration moves with the tires to the rear which would help to see if its a tire. I'm dealing with a similar concern. My rear tires might be out of balance, but it seems to be felt more when on Asphalt back roads. Point being I'm thinking it could be just that the road surface is rougher. Last year I got rid of KYB Shocks, and installed Bosch/Sacks. It made a big improvement. I'm still getting a little up and down vibration from the rear that comes and goes. Hoping it's not Flat Spots on the Yokohamas, or Universals, or suspension issues. Not a major issue just a little annoying. |
Lo-Fi Version | Time is now: 16th May 2024 - 07:51 PM |
