Exhaust ports and sealing...., ..how do you know? |
falcor75 |
Feb 23 2017, 12:50 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
How do you know you get a good seal at the exhaust port?
The only way to really know is to take down the heaterbox and look for soot on the copper gaskets. But by then you will need to anneal the gasket again and hope that you get a good seal the next time you mount the heater box too.... Tips and tricks are most welcome.... |
bandjoey |
Feb 23 2017, 04:31 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
OK this might be crazy but what about a torque wrench? I heat mine, push them in place with a small screwdriver handle, and they always stay put. quickly put on the exhaust and torque. Have installed about 4-5 x this way and (so far) no leaks. The first time i discovered some crud on the seating area. Carefully cleaned the seating surface and no problems yet.
Lo-Fi Version | Time is now: 17th May 2024 - 04:01 PM |
