Exhaust ports and sealing...., ..how do you know? |
falcor75 |
Feb 23 2017, 12:50 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
How do you know you get a good seal at the exhaust port?
The only way to really know is to take down the heaterbox and look for soot on the copper gaskets. But by then you will need to anneal the gasket again and hope that you get a good seal the next time you mount the heater box too.... Tips and tricks are most welcome.... |
IronHillRestorations |
Feb 26 2017, 07:12 AM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Exhaust pressures will be way more than .5 bar, think mild explosion.
It should seal completely. More leveling with the big file. I don't think you cut enough material with 1200 grit sand paper. I've never heated the copper sealing rings, ever. I'm not going to say it doesn't help, I've just never had to do it. You can use a little grease to stick the copper ring in it's place, and I always use anti seize on the exhaust studs. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:43 PM |
