Exhaust ports and sealing...., ..how do you know? |
falcor75 |
Feb 23 2017, 12:50 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
How do you know you get a good seal at the exhaust port?
The only way to really know is to take down the heaterbox and look for soot on the copper gaskets. But by then you will need to anneal the gasket again and hope that you get a good seal the next time you mount the heater box too.... Tips and tricks are most welcome.... |
N_Jay |
Feb 23 2017, 05:19 PM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
On this topic:
Is there really any difference between the early and late sealing rings? They have different part numbers, but I thought the exhaust ports were all the same. If you hunt you can get rings at about $1 so why bother reusing? |
N_Jay |
Feb 24 2017, 10:00 AM
McMark |
Feb 24 2017, 10:07 AM
On this topic: Is there really any difference between the early and late sealing rings? They have different part numbers, but I thought the exhaust ports were all the same. Anyone? . . . Anyone? . . . . . . . . Beuler? Yes, but it's negligible. The early ones have a slightly smaller ID. You'd be hard pressed to identify one vs the other without having them next to each other. |
bdstone914 |
Feb 26 2017, 07:22 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
On this topic: Is there really any difference between the early and late sealing rings? They have different part numbers, but I thought the exhaust ports were all the same. Anyone? . . . Anyone? . . . . . . . . Beuler? Yes, but it's negligible. The early ones have a slightly smaller ID. You'd be hard pressed to identify one vs the other without having them next to each other. I thought the difference was size of the hole and the 2.0L used the larger hole. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:47 PM |
