speedo angle drive is loose. |
yellow75 |
Feb 23 2017, 04:51 PM
Member Group: Members Posts: 88 Joined: 1-October 16 From: pittsburgh Member No.: 20,452 Region Association: None |
Leaking and will turn back and forth. Cure?
tygaboy |
Feb 23 2017, 05:00 PM
914 Guru Group: Members Posts: 5,269 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I had the exact same issue. I got a replacement from Dr. Evil.
yellow75 |
Feb 23 2017, 05:03 PM
Dr. Evil? Link?
Mark Henry |
Feb 23 2017, 05:48 PM
It happens and there is no fix, if working and not leaking it won't hurt anything.
Leaking the odd drip only hurts the floor. (IMG:style_emoticons/default/shades.gif) |
tygaboy |
Feb 23 2017, 05:51 PM
Dr. Evil? Link? His user name here is: Dr Evil Here's a thread he started. PM him and see if he can help. He's the overall transmaster... http://www.914world.com/bbs2/index.php?sho...=188120&hl= |
yellow75 |
Feb 23 2017, 06:15 PM
oh it's leaking alright..thanks for the link..
It happens and there is no fix, if working and not leaking it won't hurt anything. Leaking the odd drip only hurts the floor. (IMG:style_emoticons/default/shades.gif) A leaking angle drive can leak into the cable sheath, and the cable can actually push the fluid up into the cockpit. I had a few pairs of pants with odd dark spots near the right knee; I finally found that there was gear oil leaking from where the speedo cable hooked up to the gauge!! --DD |
Mark Henry |
Feb 23 2017, 06:17 PM
It happens and there is no fix, if working and not leaking it won't hurt anything. Leaking the odd drip only hurts the floor. (IMG:style_emoticons/default/shades.gif) A leaking angle drive can leak into the cable sheath, and the cable can actually push the fluid up into the cockpit. I had a few pairs of pants with odd dark spots near the right knee; I finally found that there was gear oil leaking from where the speedo cable hooked up to the gauge!! --DD it just loves you... (IMG:style_emoticons/default/wub.gif) |
iankarr |
Feb 23 2017, 06:42 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
914 kisses
Lo-Fi Version | Time is now: 24th April 2024 - 10:03 PM |
