quick question...., Move pedal assembly a little to the left.... |
Tjmrfe |
Feb 23 2017, 04:56 PM
NON IMPEDING RATIONE COGITATIONIS Group: Members Posts: 132 Joined: 10-April 15 From: Cornwall on Hudson, New York Member No.: 18,612 Region Association: North East States |
Hey Guys....
Obviously I'm bored...and my feet are too big, Has anyone heard of or know of anyone moved the pedal assembly A little to the left? It's a little tight under there...I haven't looked into,it, but thought I'd ask to see if anyone has done so? Thanks! |
rgalla9146 |
Feb 23 2017, 05:20 PM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Lets see now.
Move the three master cylinder holes, one ~ 1.5" two 8mm Move the two pedal cluster mount studs. Extend the throttle arm + extend the clutch arm or cut the side of the tunnel away and angle the cables to the left. Move the two 6mm gas pedal mount welded nuts. Widen the slots on the toe board, or move the board to the left. OR..... drive barefoot ? |
Bob L. |
Feb 23 2017, 06:56 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Lets see now. Move the three master cylinder holes, one ~ 1.5" two 8mm Move the two pedal cluster mount studs. Extend the throttle arm + extend the clutch arm or cut the side of the tunnel away and angle the cables to the left. Move the two 6mm gas pedal mount welded nuts. Widen the slots on the toe board, or move the board to the left. OR..... drive barefoot ? Don't forget the reinforcing plate under the floor. |
GeorgeRud |
Feb 23 2017, 07:13 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I've been driving barefoot for many years to fit my size 13s in the available space. I keep looking for some driving shoes that would work.
JamesM |
Feb 23 2017, 07:20 PM
Senior Member Group: Members Posts: 1,905 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
get rid of your center console
BK911 |
Feb 23 2017, 08:37 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
On an episode of phantom works, they used heat, then bent the pedal arms a little bit.
Wasnt on a 914, but might work. |
76-914 |
Feb 23 2017, 09:15 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I did exactly that on my old Karmann Ghia. You just need to heat and bend the clutch pedal. (IMG:style_emoticons/default/beerchug.gif)
Chris914n6 |
Feb 23 2017, 11:37 PM
Jackstands are my life. Group: Members Posts: 3,327 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Yep. Clutch pedal fits fine. Bent the brake pedal 1" left. Slid the gas pedal 1" left with a bracket. No more rubbing foot against tunnel carpet making a hole.
Now the steering wheel feels way off, like 1 3/4" off (IMG:style_emoticons/default/screwy.gif) |
Tjmrfe |
Feb 24 2017, 07:10 AM
Hey Guys.... Obviously I'm bored...and my feet are too big, Has anyone heard of or know of anyone moved the pedal assembly A little to the left? It's a little tight under there...I haven't looked into,it, but thought I'd ask to see if anyone has done so? Thanks! Okay....thanks for the input! I'll see how bored I really am, and put my time where my mouth is....If I do I'll be sure to complain and brag accordingly...thanks again.... |
My 914 |
Feb 24 2017, 07:14 AM
Casual Member Group: Members Posts: 560 Joined: 23-April 16 From: Massachusetts Member No.: 19,928 Region Association: North East States |
I think some driving shoes or at least a pair of low profile sneakers that hold your feet snug would be the easiest short term solution (its what I do now)
Front yard mechanic |
Feb 24 2017, 07:43 AM
Senior Member Group: Members Posts: 1,166 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
There are hunziker driving shoes on sale at the bird (IMG:style_emoticons/default/type.gif)
Lo-Fi Version | Time is now: 26th May 2024 - 01:01 PM |
