Street Driven 914-6 spring rates |
914forme |
Feb 23 2017, 06:00 PM
Look for some recommendations.
Stock 914-6 with stock T bars, front 22mm H&H Swaybar - adjustable, and rear spring rate of ?????? I was thinking 170. Shocks are all Bilstien Sports, springs are 2.25" size so I can pick most any rate I want including variables, just not sure what to run on a street drive 914-6. |
okieflyr |
Feb 23 2017, 07:39 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
What kind of rear suspension action are you looking for?
Sport or soft? What are the road conditions that you are on the most? I have a 4cyl water cooled conversion@ 2200 lbs and use 225lb springs and like them. Good for most roads, but they do sacrifice compliance on the rough stuff. I would put these in the sport category, but very tolerable for long distance drives. BTW my tires are 205/55/16's. |
914_teener |
Feb 23 2017, 07:46 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Why not progressive?
914forme |
Feb 23 2017, 08:57 PM
What kind of rear suspension action are you looking for? Sport or soft? What are the road conditions that you are on the most? I have a 4cyl water cooled conversion@ 2200 lbs and use 225lb springs and like them. Good for most roads, but they do sacrifice compliance on the rough stuff. I would put these in the sport category, but very tolerable for long distance drives. BTW my tires are 205/55/16's. Sport, I don't drive anything that is stock |
Feb 23 2017, 09:12 PM
I've driven a narrow body 3.2 conversion with 180# springs that felt harsh and a flared 3.0 with 225# springs that felt fine. So I have no idea but I think each car may be a little different and you might just have to give it your best guess. I have 165# in my car now but still not on the road. I don't think I can go any lighter with my 3.2 and still hold up the car.
914_teener |
Feb 24 2017, 12:17 AM
http://www.hypercoils.com/spring-calculator
Sway bars change the rate calculation....there is another site that calculates that as well but I can.t find it at the moment. |
jmitro |
Feb 24 2017, 07:18 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
I would add that good dampers play as much role in ride comfort as the spring rate.
Justinp71 |
Feb 24 2017, 11:31 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I run 200# springs with my 3.2 and I think its a good balance. I think its all a personal preference. Also I've heard anything over 200# starts to put additional stress on the body. If your not track racing it, its probably not a big deal though. Also how tall of tires do you have? The less sidewall you have the more spring your going to want. |
ConeDodger |
Feb 24 2017, 11:33 AM
Apex killer! Group: Members Posts: 23,560 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Mine are 200# in the rear with my 3.2...
Lo-Fi Version | Time is now: 26th April 2024 - 07:20 PM |
