tire options for 15", street and track |
jmitro |
Feb 25 2017, 09:28 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
I have 3 sets of 15" rims, so I'm not interested in upsizing to 16"
I have 15x7/8 and looking for street tires (should be pretty easy) and track tires (seems pretty difficult). Street tires - 205/60R15? but I'm having a hard time finding similar size DE tires. Suggestions? |
horizontally-opposed |
Feb 25 2017, 09:42 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I have 3 sets of 15" rims, so I'm not interested in upsizing to 16" I have 15x7/8 and looking for street tires (should be pretty easy) and track tires (seems pretty difficult). Street tires - 205/60R15? but I'm having a hard time finding similar size DE tires. Suggestions? I've got a long thread on 914world.com somewhere detailing the search for good street/track or street or track tires for 15-inch wheels. Ah, found it... http://www.914world.com/bbs2/index.php?sho...39516&st=20 I eventually went with Avon CR6ZZ 185/70R15s all around and like them. Would have preferred a 205/60R15, but the only game in town is the Yokohama A048. That's a good game, if the tread pattern doesn't bother you and 205/60 all around does it for you. If you want period looks and good performance, there are two strong options: Avon CR6ZZ in 185/70 and 215/60R15 (available in 2-3 compounds, from rally to race) Pirelli CN36 in 185/70 and 215/60R15 (old looks, modern compound, tested well in Europe) Roger Krause is a good supplier for the Avons, and I've been happy with them. Went with the hardest compound, as mine is a street car, and they still probably have more grip than some performance 205s...which are NLA anyway...and way more grip than an all-season 205/60. If you don't care about looks, or like 50-series tires, Toyo RA1s in 205/50 and 225/50 is another option. Everything else I saw were all-season tires. YMMV... |
914forme |
Feb 25 2017, 09:56 PM
I just pulled 11 205/50-15s in street / track compounds
G-Force Rivals But I would go with the Bridgestone Potenza RE-71s But that is me |
jmitro |
Feb 25 2017, 10:03 PM
205/50/15 is too small a diameter; I want the tire size to basically match the OEM diameter.
Thanks h-o - I'll look those tires up. I've always like yokos. EDIT - great information in your thread above. You've done a lot of research and that helps a lot! |
Tom_T |
Feb 25 2017, 10:30 PM
Try Lucas Tires & look at their UK group Longstone too, since they can get anything from there at Lucas, including Avon & Dunlop race tires.
http://www.lucasclassictires.com/ http://www.longstonetyres.co.uk/index http://www.longstonetyres.co.uk/page/porsche-914 For street, I like their Blockley OE size 165R15 (/80) as a close match to what the original Dunlop SP57s were like & the Semperit M401/M501, & they also make them in 185s. http://www.lucasclassictires.com/165VR15-B...Radial-504p.htm http://www.lucasclassictires.com/Blockley_c30.htm (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Feb 25 2017, 11:04 PM
I used to run 205/55s, and would consider these 205/55s if:
a) I wanted to go back to short sidewalls b) I wanted the performance and was planning to put a lot of miles on my 914 c) I could deal with the sidewalls (same as a 2012 radio in a 1973 dashboard) https://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes I do hear good things about them... |
rick 918-S |
Feb 27 2017, 11:27 PM
Hey nice rack! -Celette Group: Members Posts: 20,431 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I used to run 205/55s, and would consider these 205/55s if: a) I wanted to go back to short sidewalls b) I wanted the performance and was planning to put a lot of miles on my 914 c) I could deal with the sidewalls (same as a 2012 radio in a 1973 dashboard) https://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes I do hear good things about them... (IMG:style_emoticons/default/agree.gif) Short sidewalls have their place. At an AX event, track day etc. I am totally into a period correct look. Fat tires with sidewalls on cars that were designed to run on them. |
Bgyglfr |
Feb 28 2017, 03:08 AM
Member Group: Members Posts: 55 Joined: 6-December 14 From: Springfield IL Member No.: 18,191 Region Association: Upper MidWest |
I have run direzzas on my narrow 911s and love them. I was considering doing them for my 914 too.
For DE you might consider RA1s. 225/50/15 and 205/50/15 for 7/8 x 15. Very sticky tires that have a good life span. I know a lot of 911 guys that run them on the street and get 10k or so miles. Again, short sidewall but that should help performance by shortening the gear ratios. |
Feb 28 2017, 03:16 AM
(IMG:style_emoticons/default/agree.gif) Short sidewalls have their place. At an AX event, track day etc. I am totally into a period correct look. Fat tires with sidewalls on cars that were designed to run on them. I just wish we could have our cake and eat it too, with a 205/60R15 re-pop of the A-008 RSII—or that tire tread and sidewall design on the current A043. 205/60R15 is the perfect size for narrow 914s and 914-6s. A-008s may be a bit off on period, but they're plain enough and 30 years old—so I'll call them "period." They're what were on the cars by the time I noticed people having fun with them! (IMG:style_emoticons/default/chowtime.gif) |
wndsrfr |
Feb 28 2017, 06:21 AM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
I have 3 sets of 15" rims, so I'm not interested in upsizing to 16" I have 15x7/8 and looking for street tires (should be pretty easy) and track tires (seems pretty difficult). Street tires - 205/60R15? but I'm having a hard time finding similar size DE tires. Suggestions? I'm on Toyo RR's for the track, 225/45/15 & 225/50/15....I'm flared, dk about narrow car. Second the suggestion about RA1's for both street & track. BTW, getting the RA1's shaved for the track cuts heat buildup & squirm.... |
jmitro |
Feb 28 2017, 07:36 AM
great, thanks so much for the help (IMG:style_emoticons/default/beerchug.gif)
my car has GT flares by the way. probably what I'll do is use 205/60/15 for the street and 225/50 for the track. The overall diameter is a tad small but probably not that big a deal. |
stugray |
Feb 28 2017, 12:11 PM
I run spec Miata Hoosiers on the track.
Look up 'Hoosier SM7' (205/50ZR15). They fit on my 7" wheels fine, so should be OK on 8 in wide as well. (they actually work on my 5.5 inch FUCHS too, but not optimal) |
pvollma |
Feb 28 2017, 01:15 PM
Member Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region |
great, thanks so much for the help (IMG:style_emoticons/default/beerchug.gif) my car has GT flares by the way. probably what I'll do is use 205/60/15 for the street and 225/50 for the track. The overall diameter is a tad small but probably not that big a deal. If you want to assess the impact of the difference in tire diameter (actually, revs/mile), then feel free to use my Gear Chart Program. It will produce a chart of MPH for each 200 RPM from 2000 RPM to your entered maximum for the given tire size. |
GeorgeRud |
Feb 28 2017, 03:02 PM
With all the early 911s and 914s out there with 15" wheels, you' think some enterprising individual (or tire company) would make a batch of tires in appropriate sizes. They could even do a preorder program so they'd know what their market would be.
Having said that, a friend just shod his 911SC with Cooper tires and is very satisfied with their performance. I think many of today's all season tires may be the equal of the 'hot.shot' tires of yesteryear. |
914dave |
Feb 28 2017, 04:51 PM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Try Lucas Tires & look at their UK group Longstone too, since they can get anything from there at Lucas, including Avon & Dunlop race tires. http://www.lucasclassictires.com/ http://www.longstonetyres.co.uk/index http://www.longstonetyres.co.uk/page/porsche-914 For street, I like their Blockley OE size 165R15 (/80) as a close match to what the original Dunlop SP57s were like & the Semperit M401/M501, & they also make them in 185s. http://www.lucasclassictires.com/165VR15-B...Radial-504p.htm http://www.lucasclassictires.com/Blockley_c30.htm (IMG:style_emoticons/default/beerchug.gif) Tom /////// I used Longstone for Pirelli P Zeros. 225/50/15 for my flared car. They were HALF the price of tire rack delivered. |
Dougal Cawley |
Mar 23 2017, 10:59 AM
Newbie Group: Members Posts: 18 Joined: 23-March 17 From: Longstone Tyres Member No.: 20,953 Region Association: England |
Hi
For 205/50YR15 there is the Porsche homologated P7 N4 http://www.longstonetyres.co.uk/page/205-5...rato-p7-n4.html and a 225/50 http://www.longstonetyres.co.uk/page/225-5...rato-p7-n4.html (IMG:http://www.914world.com/bbs2/uploads_offsite/www.longstonetyres.co.uk-20953-1490288338.1.jpg) But there is also a 215/60 Cinturato CN36 N4 http://www.longstonetyres.co.uk/page/pirelli-cinturato-cn36 But a 914, i think would originally fit http://www.longstonetyres.co.uk/page/165hr...urato-ca67.html (IMG:http://www.914world.com/bbs2/uploads_offsite/www.cinturato.net-20953-1490288339.2.png) then maybe after 1968 they introduced the http://www.longstonetyres.co.uk/page/165vr...to-cn36-n4.html (IMG:http://www.914world.com/bbs2/uploads_offsite/www.cinturato.net-20953-1490288340.3.png) |
Justinp71 |
Mar 23 2017, 11:06 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I've been running Nitto NT-01's 225/45/15 on a set of 7/8 for about 5 years now. I love them, they almost grip too well the car always feels hooked to the ground. This is what they look like- Attached thumbnail(s) |
Dougal Cawley |
Mar 30 2017, 09:35 AM
Have you thought about these http://www.longstonetyres.co.uk/page/18-60...helin-tb15.html
They are amazing |
Mark Henry |
Mar 30 2017, 11:31 AM
But nothing decent in a 205/60-15 to fit a narrow body. (IMG:style_emoticons/default/dry.gif)
Almost thinking I should sell my real 6x15 fuchs and buy the euromiester 7X17" rims. I'll have to make the decision before I start my bodywork this fall. |
yeahmag |
Mar 30 2017, 12:36 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
For autocross I've had great luck with the Z214 in the soft compound in 205-50-15:
https://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes For street I run the previous generation of this tire and like it fine: https://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes ...also makes a decent autocross "street" tire. Obviously neither of those are a "60" side wall... |
Lo-Fi Version | Time is now: 2nd May 2024 - 07:08 AM |
