Does the paint in the trunks always match the exterior from the factory? |
pmead |
Feb 26 2017, 08:23 AM
Newbie Group: Members Posts: 20 Joined: 5-February 17 From: Lewes Delaware Member No.: 20,813 Region Association: MidAtlantic Region |
I have a Saturn Yellow 73' Someone has resprayed it in a non-correct yellow. They did a terrible job. I have found a couple of chipped areas in the trunk that show a greenish yellow (to green for Saturn yellow) color under the yellow. Weird color for a primer, does not act/look like bondo. Did the trunk area match the exterior for a 73' 1.7 car? When I repaint I want it to be correct. Is it possible that some PO changed the paint code plate?
pmead |
Feb 26 2017, 03:23 PM
I have done quite a few "rusterations" and this looks good from what I can see so far. The truth we will be told when I strip it and see if all rust was removed, how the seams look, how much bondo etc..... I wont get to it until this summer. The mechanicals seem well sorted other than a bad vacuum pod on the dizzy. Usually when people spend time and do one part of a build correctly the rest of the job was done correctly as well. I think this paint job probably looked good when it was completed. The spider webbing and cracking can happen over time when enamel is to thick, or multiple coats are applied to quickly.
Lo-Fi Version | Time is now: 19th May 2024 - 04:14 PM |
