Coil Over assembly..., I just gotta be sure |
tygaboy |
Feb 26 2017, 12:50 PM
914 Guru Group: Members Posts: 5,294 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Can I get a confirmation of what else, if anything, I need as I assemble the coil over kit?
Is there some sort of bushing/washer that lives on the shaft UNDER the top spring hat that supports it? All I got was the plastic washer that slides down the shaft and sit on the shock body. I watched this video and nothing is mentioned or used. https://www.youtube.com/watch?v=SGIrZ1sJVdc It just seems like there'd be something more so I figured better to ask and be safe than sorry. Thanks in advance. Chris Attached thumbnail(s) |
jd74914 |
Feb 27 2017, 10:06 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
You're saying your top hat never hits a stop on the shaft-so it would fall all the way to the damper body if there was no spring?
My Coleman tops are the same. I'll grab a picture for you. |
tygaboy |
Feb 27 2017, 10:15 AM
You're saying your top hat never hits a stop on the shaft-so it would fall all the way to the damper body if there was no spring? My Coleman tops are the same. I'll grab a picture for you. A pic would be great. And I'm saying my hat does contact that first lip but it sure doesn't seem like a "positive" fit that should/would take any sort of load. I think that must be why Tony's car shows so much thread out the top: He opened up the hat so it does slide all the way down so he's "lost" the thickness of the hat in his assembly, allowing more thread to poke out the top. Anyway, am I just being paranoid? (IMG:style_emoticons/default/wacko.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 01:00 AM |
