Coil Over assembly..., I just gotta be sure |
tygaboy |
Feb 26 2017, 12:50 PM
914 Guru Group: Members Posts: 5,298 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Can I get a confirmation of what else, if anything, I need as I assemble the coil over kit?
Is there some sort of bushing/washer that lives on the shaft UNDER the top spring hat that supports it? All I got was the plastic washer that slides down the shaft and sit on the shock body. I watched this video and nothing is mentioned or used. https://www.youtube.com/watch?v=SGIrZ1sJVdc It just seems like there'd be something more so I figured better to ask and be safe than sorry. Thanks in advance. Chris Attached thumbnail(s) |
ChrisFoley |
Feb 27 2017, 12:49 PM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Stephen, if you had bored the id of your sleeve for clearance on the shock shaft below the step, you could have extended the shock further without losing the space between tophat and the shock tower.
OTOH, if the shock never bottoms with the existing arrangement, there's no added benefit. |
Lo-Fi Version | Time is now: 27th May 2024 - 07:23 AM |
