914-6 runs HOT - solved? |
767driver |
Feb 26 2017, 03:28 PM
Newbie Group: Members Posts: 34 Joined: 13-January 12 From: Baltimore, MD Member No.: 14,002 Region Association: MidAtlantic Region |
Hi guys,
Lurked here for a number of years and have finally landed a 914-6. It's a 1970 with it's numbers-matching case running a (stock?) 66mm crank and 86mm pistons for a displacement of 2.3L. It runs Solex cams and 40 Webers. It's only got about 600 miles since rebuild. So the engine is somewhat upgraded but nothing too wild. When I drove it the 45 mostly-highway miles to my house I noticed it was getting a bit warm. The weather was about 60 degrees. The indicator on the factory oil temp gauge was reading about 3/4. The next day I took the car for a nice "getting acquainted" kind of run on mixed highway and country roads. After 25 minutes on the highway at 80 mph and about 3500 rpms it was getting really warm...almost touching the hashed red part of the hot end of the scale. I immediately went over to a buddy's shop and shot an IR thermometer at the rear of the oil cooler. Got temps of 220 or so at top of cooler and 250-260 at bottom. The cooler still has a Stoddard Porsche decal on it. I checked and the cooler is the $1335 German-made part. Oil quantity ok. Now I know this is not enough motor to overload the factory oil cooling assuming everything is working correctly. I took the thermostat out of the car and performed the pot-of-hot-water-with-thermometer-trick and verified it opens and closes as it should. I guess the in-dash gauge could be wrong, but the IR thermometer seemed to confirm the high reading. All the tins appear to be in place. I have read the cylinder baffles can be installed upside down causing issues. And that the cylinders themselves can be installed upside down. I guess that new-ish oil cooler might be defective...that's an engine drop...right? Ignition timing, cam timing, fuel mixture need to be checked. And none of the cabin heating air tubes are on the car. The 2 supply ducts off either side of the engine cooling fan duct are capped. Is the fact that no fan air is going through the heat exchangers causing the one under the oil cooler to run hot enough to cause the high oil temps? ANSWER: YES So...what have I forgotten or overlooked here. I had 2 VERY knowledgeable Porschephiles tell me that barring an oil cooler issue it is almost surely a hot bearing (youch!) making that kind of heat. Any thoughts or ideas are appreciated. 1970 914-6 VIN 9140432125 Engine 6405400 |
Cairo94507 |
Feb 27 2017, 05:54 PM
Michael Group: Members Posts: 9,789 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Here they are. I believe they came standard beginning in '73. I am adding these (I know, my Six did not come with them) on my car because it can't hurt to get a little more air flow for the motor. |
Justinp71 |
Feb 27 2017, 06:40 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Here they are. I believe they came standard beginning in '73. I am adding these (I know, my Six did not come with them) on my car because it can't hurt to get a little more air flow for the motor. Hmm, I wondered what those were for. I guess these help because at higher speeds the flow across the bottom of the car is too strong for the air coming thru the engine to merge? Does anyone know? |
Dave_Darling |
Feb 28 2017, 02:48 PM
I guess these help because at higher speeds the flow across the bottom of the car is too strong for the air coming thru the engine to merge? Does anyone know? Something like that. The flaps create turbulence behind them, which is slightly lower pressure than the other ambient air. That lower pressure helps pull air through the cooling fins on the engine. It's not a huge effect by any means, but it is there. --DD |
Lo-Fi Version | Time is now: 25th May 2024 - 09:03 PM |
