914-6 runs HOT - solved? |
767driver |
Feb 26 2017, 03:28 PM
Newbie Group: Members Posts: 34 Joined: 13-January 12 From: Baltimore, MD Member No.: 14,002 Region Association: MidAtlantic Region |
Hi guys,
Lurked here for a number of years and have finally landed a 914-6. It's a 1970 with it's numbers-matching case running a (stock?) 66mm crank and 86mm pistons for a displacement of 2.3L. It runs Solex cams and 40 Webers. It's only got about 600 miles since rebuild. So the engine is somewhat upgraded but nothing too wild. When I drove it the 45 mostly-highway miles to my house I noticed it was getting a bit warm. The weather was about 60 degrees. The indicator on the factory oil temp gauge was reading about 3/4. The next day I took the car for a nice "getting acquainted" kind of run on mixed highway and country roads. After 25 minutes on the highway at 80 mph and about 3500 rpms it was getting really warm...almost touching the hashed red part of the hot end of the scale. I immediately went over to a buddy's shop and shot an IR thermometer at the rear of the oil cooler. Got temps of 220 or so at top of cooler and 250-260 at bottom. The cooler still has a Stoddard Porsche decal on it. I checked and the cooler is the $1335 German-made part. Oil quantity ok. Now I know this is not enough motor to overload the factory oil cooling assuming everything is working correctly. I took the thermostat out of the car and performed the pot-of-hot-water-with-thermometer-trick and verified it opens and closes as it should. I guess the in-dash gauge could be wrong, but the IR thermometer seemed to confirm the high reading. All the tins appear to be in place. I have read the cylinder baffles can be installed upside down causing issues. And that the cylinders themselves can be installed upside down. I guess that new-ish oil cooler might be defective...that's an engine drop...right? Ignition timing, cam timing, fuel mixture need to be checked. And none of the cabin heating air tubes are on the car. The 2 supply ducts off either side of the engine cooling fan duct are capped. Is the fact that no fan air is going through the heat exchangers causing the one under the oil cooler to run hot enough to cause the high oil temps? ANSWER: YES So...what have I forgotten or overlooked here. I had 2 VERY knowledgeable Porschephiles tell me that barring an oil cooler issue it is almost surely a hot bearing (youch!) making that kind of heat. Any thoughts or ideas are appreciated. 1970 914-6 VIN 9140432125 Engine 6405400 |
gereed75 |
Feb 28 2017, 05:10 PM
Senior Member Group: Members Posts: 1,247 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Rgalla, not trying to be argumentative or steal this thread, but how does retarded timing increase temps??
My understanding is that timing advanced beyond optimal increases peak internal combustion pressure. That higher pressure results in higher heat and reduces engine output. What mechanism/physics makes retarded timing produce more heat/higher temps?? |
rgalla9146 |
Mar 1 2017, 11:07 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Rgalla, not trying to be argumentative or steal this thread, but how does retarded timing increase temps?? My understanding is that timing advanced beyond optimal increases peak internal combustion pressure. That higher pressure results in higher heat and reduces engine output. What mechanism/physics makes retarded timing produce more heat/higher temps?? Retarded timing allows partial combustion pressure to escape through the opening exhaust valve which raises cyl. head/ oil temp. There is more to it than that. Google ignition timing vs. engine temp |
Lo-Fi Version | Time is now: 18th May 2024 - 06:52 PM |
