New member - introduction and questions... |
pugface |
Feb 26 2017, 07:06 PM
Newbie Group: Members Posts: 15 Joined: 8-January 17 From: Boerne, TX Member No.: 20,735 Region Association: None |
Hi guys
New member here, figured I should introduce myself, as I may be asking lots of questions! I've wanted a 914 since seeing one of the college kids driving one when I was in high school - in the 80's. Unfortunately, living in the salty Midwest, I don't think I saw another one in person since the 80's. (IMG:style_emoticons/default/smile.gif) I've also always wanted to learn more about how to fix and restore cars. And, I have a son in middle school that hopefully can learn a little as well. Like most of you, my budget is NOT unlimited (IMG:style_emoticons/default/sad.gif) so I was looking for a car that needed some work, but not too much. And a price to reflect that. I found and bought something this month that seemingly fit the bill - a project, but one that starts, shifts, and stops. all pieces (and more) there, if not all the same color. A 1973 1.7 retaining its D-Jetronic, and NO rust. Well, pretty much no rust... So, as to the problems, when I bought I was told it won't idle once it warms up. He thought it needed the timing set. From what I can tell, it is running very rich. The oil level was high, when I changed it, it smelled of gas. Car ran well enough for me to drive it a few miles around 'the block', but I wouldn't want to go any further than that. So, with 914world as a resource, I found many things to check. But, I must admit that I am a novice at this - so to check fuel pressure, I ordered a simple fuel pressure tester kit from Amazon. But this is the first time I have attempted this, so I worry I am doing it wrong? I hooked up the fuel pressure gauge to the test point on the fuel rail between 1 & 2 with a clamp. When I turn the key, and the pump fires for a bit, it runs right up to 30 psi. I then disconnected the coil wire and cranked the engine per Haynes. The gauge jumped to 70 psi! Do I have it hooked up right? Of course, if my fuel pressure is that far off, it would explain a lot of the poor running. Adjusting the regulator per Haynes made little difference, so either my test is wrong, or the regulator is blown. Now, when I got the car, I also inherited two other 914's worth of stripped parts to various degress. I loooked through the boxes and found a second regulator, but it looked pretty sad and crusty. I installed it just to see what would happen. This time, I crank the engine, and fuel goes everywhere. My cheap Amazon fuel pressure kit came with some hose I used to splice in - that hose ruptured! WTF. I'll go into twon this week and find some high-pressure fuel hose - in the meantime, does it sound like I had the gauge in the right place? If so, I'll order a new regulator and give it a try next weekend. Thanks pf Oh, wait, you guys are going to do the THIS THREAD IS WORTHLESS... thing, aren't you? (IMG:style_emoticons/default/biggrin.gif) Here's a pic - long way to go |
falcor75 |
Feb 27 2017, 06:47 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I had a kink in the return line under the tank (newly installed hose) and the pressure buildup would not let the regulator work as intended.
The cheap way of testing this is to buy 6 feet of 8 mm fuel hose, connect it to the outlet of the regulator and run the other end into a fuel can or whatever you have that will collect the fuel for you in a safe manner. Then bypass the fuel pump relay and check the pressure again. With the regulator passing the fuel into the cannister you should see a normal fuel pressure if the problem lays with the return line. |
pugface |
Mar 4 2017, 11:15 AM
I had a kink in the return line under the tank (newly installed hose) and the pressure buildup would not let the regulator work as intended. The cheap way of testing this is to buy 6 feet of 8 mm fuel hose, connect it to the outlet of the regulator and run the other end into a fuel can or whatever you have that will collect the fuel for you in a safe manner. Then bypass the fuel pump relay and check the pressure again. With the regulator passing the fuel into the cannister you should see a normal fuel pressure if the problem lays with the return line. Thanks - I tried this today. I bypassed the relay by jumping pins 30 and 87. Dumping into a gas can instead of the stainless return lines, I get a normal ~30 psi. Looks like I have a kink somewhere downstream - I'll back it on ramps and investigate underneath. |
ndfrigi |
Mar 4 2017, 11:35 AM
Advanced Member Group: Members Posts: 2,929 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
I had a kink in the return line under the tank (newly installed hose) and the pressure buildup would not let the regulator work as intended. The cheap way of testing this is to buy 6 feet of 8 mm fuel hose, connect it to the outlet of the regulator and run the other end into a fuel can or whatever you have that will collect the fuel for you in a safe manner. Then bypass the fuel pump relay and check the pressure again. With the regulator passing the fuel into the cannister you should see a normal fuel pressure if the problem lays with the return line. Thanks - I tried this today. I bypassed the relay by jumping pins 30 and 87. Dumping into a gas can instead of the stainless return lines, I get a normal ~30 psi. Looks like I have a kink somewhere downstream - I'll back it on ramps and investigate underneath. do you have the 3 port fuel pump? maybe it has some issue with it? maybe you can remove the rubber fuel before ss engine fuel line and also check if it will drain fuel from from tank return line. |
Lo-Fi Version | Time is now: 22nd May 2024 - 08:24 PM |
