New member - introduction and questions... |
pugface |
Feb 26 2017, 07:06 PM
Newbie Group: Members Posts: 15 Joined: 8-January 17 From: Boerne, TX Member No.: 20,735 Region Association: None |
Hi guys
New member here, figured I should introduce myself, as I may be asking lots of questions! I've wanted a 914 since seeing one of the college kids driving one when I was in high school - in the 80's. Unfortunately, living in the salty Midwest, I don't think I saw another one in person since the 80's. (IMG:style_emoticons/default/smile.gif) I've also always wanted to learn more about how to fix and restore cars. And, I have a son in middle school that hopefully can learn a little as well. Like most of you, my budget is NOT unlimited (IMG:style_emoticons/default/sad.gif) so I was looking for a car that needed some work, but not too much. And a price to reflect that. I found and bought something this month that seemingly fit the bill - a project, but one that starts, shifts, and stops. all pieces (and more) there, if not all the same color. A 1973 1.7 retaining its D-Jetronic, and NO rust. Well, pretty much no rust... So, as to the problems, when I bought I was told it won't idle once it warms up. He thought it needed the timing set. From what I can tell, it is running very rich. The oil level was high, when I changed it, it smelled of gas. Car ran well enough for me to drive it a few miles around 'the block', but I wouldn't want to go any further than that. So, with 914world as a resource, I found many things to check. But, I must admit that I am a novice at this - so to check fuel pressure, I ordered a simple fuel pressure tester kit from Amazon. But this is the first time I have attempted this, so I worry I am doing it wrong? I hooked up the fuel pressure gauge to the test point on the fuel rail between 1 & 2 with a clamp. When I turn the key, and the pump fires for a bit, it runs right up to 30 psi. I then disconnected the coil wire and cranked the engine per Haynes. The gauge jumped to 70 psi! Do I have it hooked up right? Of course, if my fuel pressure is that far off, it would explain a lot of the poor running. Adjusting the regulator per Haynes made little difference, so either my test is wrong, or the regulator is blown. Now, when I got the car, I also inherited two other 914's worth of stripped parts to various degress. I loooked through the boxes and found a second regulator, but it looked pretty sad and crusty. I installed it just to see what would happen. This time, I crank the engine, and fuel goes everywhere. My cheap Amazon fuel pressure kit came with some hose I used to splice in - that hose ruptured! WTF. I'll go into twon this week and find some high-pressure fuel hose - in the meantime, does it sound like I had the gauge in the right place? If so, I'll order a new regulator and give it a try next weekend. Thanks pf Oh, wait, you guys are going to do the THIS THREAD IS WORTHLESS... thing, aren't you? (IMG:style_emoticons/default/biggrin.gif) Here's a pic - long way to go |
pugface |
Mar 6 2017, 09:57 PM
Looks like I'll be draining the gas and pulling the tank again this weekend. At least now I know how!
Lo-Fi Version | Time is now: 18th May 2024 - 12:11 AM |
