Help - spark plug fell into engine |
pugface |
Feb 26 2017, 07:16 PM
Newbie Group: Members Posts: 15 Joined: 8-January 17 From: Boerne, TX Member No.: 20,735 Region Association: None |
Sigh - followup to my first post
I pulled all the plugs today to do a compression test. My first time to ever do a compression test, so hopefully it was done right. seemed OK at 100-110-110-105 However! When I pulled the plug on cylinder 4, it fell out of the socket, and underneath the tin. I can't even see it. I got a boroscope-type thingy from Harbor Freight - I found the plug, it is lodged in there pretty good. Is there a way to retrieve this? Anybody else do something like this? I am planning on _eventually_ pulling the engine to clean and go through hoses and wiring, but do I need to get that plug out ASAP, or can it stay there for a bit? (IMG:style_emoticons/default/smile.gif) * This is what always stops me from working on cars - bad luck. Of course, in other fields, I say "You make your own luck", so I don't really believe in luck, but man, do I have some bad luck with cars. Or just plain incompetence (IMG:style_emoticons/default/smile.gif) Thanks pf |
mepstein |
Feb 26 2017, 07:21 PM
914-6 GT in waiting Group: Members Posts: 19,268 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I've found a couple plugs in engines - other tools and parts as well. Normally it won't hurt anything. Try a magnetic pickup with a flexible shaft.
It's usually small nuts, bolts and screws, dropped down the intake, injector or spark plug hole, that trash the engine. (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 13th May 2024 - 07:01 PM |
