Help - spark plug fell into engine |
pugface |
Feb 26 2017, 07:16 PM
Newbie Group: Members Posts: 15 Joined: 8-January 17 From: Boerne, TX Member No.: 20,735 Region Association: None |
Sigh - followup to my first post
I pulled all the plugs today to do a compression test. My first time to ever do a compression test, so hopefully it was done right. seemed OK at 100-110-110-105 However! When I pulled the plug on cylinder 4, it fell out of the socket, and underneath the tin. I can't even see it. I got a boroscope-type thingy from Harbor Freight - I found the plug, it is lodged in there pretty good. Is there a way to retrieve this? Anybody else do something like this? I am planning on _eventually_ pulling the engine to clean and go through hoses and wiring, but do I need to get that plug out ASAP, or can it stay there for a bit? (IMG:style_emoticons/default/smile.gif) * This is what always stops me from working on cars - bad luck. Of course, in other fields, I say "You make your own luck", so I don't really believe in luck, but man, do I have some bad luck with cars. Or just plain incompetence (IMG:style_emoticons/default/smile.gif) Thanks pf |
dangrouche |
Feb 26 2017, 08:14 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
if you know where it is located, you can buy one of those remote gripping tools, very similar in design to the harbor freight magnet at the end of flexible spring rod. other wise a very strong magnet at the end of a stick would be the simplest. good luck.
Lo-Fi Version | Time is now: 14th May 2024 - 01:09 AM |
