Help - spark plug fell into engine |
pugface |
Feb 26 2017, 07:16 PM
Newbie Group: Members Posts: 15 Joined: 8-January 17 From: Boerne, TX Member No.: 20,735 Region Association: None |
Sigh - followup to my first post
I pulled all the plugs today to do a compression test. My first time to ever do a compression test, so hopefully it was done right. seemed OK at 100-110-110-105 However! When I pulled the plug on cylinder 4, it fell out of the socket, and underneath the tin. I can't even see it. I got a boroscope-type thingy from Harbor Freight - I found the plug, it is lodged in there pretty good. Is there a way to retrieve this? Anybody else do something like this? I am planning on _eventually_ pulling the engine to clean and go through hoses and wiring, but do I need to get that plug out ASAP, or can it stay there for a bit? (IMG:style_emoticons/default/smile.gif) * This is what always stops me from working on cars - bad luck. Of course, in other fields, I say "You make your own luck", so I don't really believe in luck, but man, do I have some bad luck with cars. Or just plain incompetence (IMG:style_emoticons/default/smile.gif) Thanks pf |
forrestkhaag |
Feb 27 2017, 10:33 AM
I would add one thing to the sage advice above. In addition to the piece of fuel line to grip the plug, use a piece of a pencil or brass tube top fully straighten the fuel line "tool" to allow you to accurately and more precisely start the plug into the spark plug hole. A bent hose-tool makes this basic task much more sketchy as to cross threading.
(IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 13th May 2024 - 08:28 PM |
