What is the trick to installing a new fuel line? |
Larmo63 |
Feb 26 2017, 10:10 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I've got one fuel line to install (carbs) and the engine is out. I had no luck getting the new line in further than 8 -12"
I can't imagine doing this with the engine in without bending the f*ck out of the new line.... |
toolguy |
Feb 27 2017, 10:16 AM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
The first one did I tied a string to the plastic lines and pulled it through the tunnel when I removed the OE lines. . You might try getting a wire through the car end to end first and then slide the new tubing over it, using it as a guide.
Pull the tunnel cover at the rear and the shifter in the middle for visual. . As it remember there are tabs that hold the plastic lines in place and the mid bulkhead that you have to navigate around and through. . . |
Lo-Fi Version | Time is now: 29th May 2024 - 07:00 AM |
