What is the trick to installing a new fuel line? |
Larmo63 |
Feb 26 2017, 10:10 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I've got one fuel line to install (carbs) and the engine is out. I had no luck getting the new line in further than 8 -12"
I can't imagine doing this with the engine in without bending the f*ck out of the new line.... |
forrestkhaag |
Feb 27 2017, 10:41 AM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
I used a fish tape run from the front to the back dragged thru with the original plastic line.
With low pressure carbs, you only need one line so if your plastic is still there, you have two shots at it. Otherwise lube up and stuff it / you have that one down! (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 01:42 PM |
