What is the trick to installing a new fuel line? |
Larmo63 |
Feb 26 2017, 10:10 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I've got one fuel line to install (carbs) and the engine is out. I had no luck getting the new line in further than 8 -12"
I can't imagine doing this with the engine in without bending the f*ck out of the new line.... |
mepstein |
Feb 28 2017, 06:43 AM
914-6 GT in waiting Group: Members Posts: 19,276 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
There are 2 access panels to look through. You really don't need a horoscope. The first time I did one, my teenage son helped me spot it down the tunnel with his cell phone flashlight. Took less than 10 minutes for both lines and I did not loosen or remove the shifter. WD-40 isn't lube. Use a real lube and it will slide easily. You might have to rotate it some as your spotter helps you sight it down the tunnel.
Lo-Fi Version | Time is now: 19th May 2024 - 01:06 PM |
