What is the trick to installing a new fuel line? |
mtndawg |
Feb 27 2017, 12:17 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I just did this with my car. The tunnel photos in this thread helped me.
http://www.914world.com/bbs2/index.php?showtopic=281316 |
914_teener |
Feb 27 2017, 02:14 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I just did this with my car. The tunnel photos in this thread helped me. http://www.914world.com/bbs2/index.php?showtopic=281316 I got a boroscope for Christmas. Very cool. You can get the Android ones for $35 bucks. There is a thread on them with the link. |
Keith914 |
Feb 27 2017, 03:43 PM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
I'll give it another try today with the right rear wheel off and I only have the one big line to install. I watched the video, my experience wasn't anything close to how those went in. Note, the pictures are very helpful but do not show the fuel pipes, which lie next to the passenger side of the tunnel. |
turk22 |
Feb 27 2017, 06:33 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
Larmo63 |
Feb 27 2017, 07:57 PM
The boroscope idea is great!
I have one. Thank you! |
Feb 28 2017, 06:43 AM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
There are 2 access panels to look through. You really don't need a horoscope. The first time I did one, my teenage son helped me spot it down the tunnel with his cell phone flashlight. Took less than 10 minutes for both lines and I did not loosen or remove the shifter. WD-40 isn't lube. Use a real lube and it will slide easily. You might have to rotate it some as your spotter helps you sight it down the tunnel.
Amphicar770 |
Feb 28 2017, 12:51 PM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
I used wire puller lube on the steel line and gromet. That worked well.
Engine was out when I did mine but rotation of fuel line was key. It got hung up, I removed and tried at a different angle and it went right in. Bore scope has become a must have tool for the 914. |
PlantMan |
Feb 28 2017, 12:56 PM
Member Group: Members Posts: 435 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
Yep, I just got a scope too for about $20 on Amazon....
Hooks up to the phone. |
Larmo63 |
Feb 28 2017, 02:50 PM
I'm using a boroscope, I watched the video, tried everything. No luck.
Rubber tip is now gone, at one point, I couldn't get it back out. Really frustrating. I got it quite a ways in, it seemed to go all the way to the original clips, but then wouldn't go any farther no matter what I did. I wish I would have just kept the 10mm soft line in there, it was in perfect condition. (IMG:style_emoticons/default/headbang.gif) |
Feb 28 2017, 04:07 PM
What is keeping it from moving forward? Has to be something. Are you using a helper?
clapeza |
Feb 28 2017, 06:38 PM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
Rubber tip is now gone, at one point, I couldn't get it back out. Really frustrating. I got it quite a ways in, it seemed to go all the way to the original clips, but then wouldn't go any farther no matter what I did. Mine did exactly the same thing at one point. Really frustrating! Just spit-balling here: Which hole are you feeding it through? The 10mm line hole on the right or the 8mm hole on the left? Would it fit into the hole on the left? Since that one is closer to the centerline of the car, it's less likely to catch on the sidewall of the tunnel. My 10mm line was a pain to get installed, but the 8mm line seemed to go much easier. You said it was for a carb set-up, so it doesn't matter which hole in the rear firewall it's going through, since you're only running one line. (Although many support a return line for fuel circulation.) If the holes are of different sizes...nevermind! Other ideas: have your spotter topside watch as the line moves forward in the tunnel. When it gets stuck, back it up a little and have them push down on it with only a little bit of pressure. I know it feels like it's getting caught on a tiny edge when it stops. It's the upwards angle of trying to get it in with the engine still in the car that introduces the challenge. Good luck! Keep trying...don't give up. |
Larmo63 |
Feb 28 2017, 07:44 PM
I tried and tried with the right hole, then tried the left 8mm hole.
It went right in. Drrrrrrr..... (IMG:style_emoticons/default/beer3.gif) |
Coondog |
Feb 28 2017, 10:56 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
I always thought the larger hole was easier then the smaller hole.......or was that what she thought..... (IMG:style_emoticons/default/confused24.gif)
Larmo63 |
Feb 28 2017, 11:11 PM
sjhenry1075 |
Apr 14 2017, 01:37 PM
Member Group: Members Posts: 266 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States |
This is what I did and it literally took me about 10 minutes for both. I sat under the car with my feet towards the front of the car. I fed the lines into the hole and pushed. As I pushed the lines I twisted them left and right. Each line went into the tunnel and all the way forward to the access panel near the pedals. Every time it seemed as if they were held up I twisted some more and they eventually worked their way forward.
Lo-Fi Version | Time is now: 7th May 2024 - 01:37 PM |
