FS: distributor, New distributor and fuel pump |
KevinW |
Feb 27 2017, 05:03 PM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
New distributor with electronic ignition and a new Mr. Gasket 4-7 psi
fuel pump. $100 shipped CONUS Attached thumbnail(s) |
andreic |
Feb 28 2017, 10:51 PM
Member Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
What make is this distributor? How does it adjust the timing? Is it purely centrifugal, or does it also have a vacuum port? What would the price be just for the distributor (don't need the fuel pump)?
Thanks, Andrei New distributor with electronic ignition and a new Mr. Gasket 4-7 psi fuel pump. $100 shipped CONUS |
KevinW |
Mar 1 2017, 04:42 AM
What make is this distributor? How does it adjust the timing? Is it purely centrifugal, or does it also have a vacuum port? What would the price be just for the distributor (don't need the fuel pump)? Thanks, Andrei New distributor with electronic ignition and a new Mr. Gasket 4-7 psi fuel pump. $100 shipped CONUS Andrei I will check when I get home from work today. There is no vacuum port. $80 shipped CONUS |
Lo-Fi Version | Time is now: 16th May 2024 - 02:53 AM |
