Adding a Hand Throttle Lever when you have an Appearance Group Console, This is one way to accomplish it. |
jkb944t |
Mar 2 2017, 12:00 PM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I installed a new throttle hand lever and then I tried to test fit a new appearance group console. I found that the throttle lever was way too far forward to work as designed with the console.
See this thread for more details: http://www.914world.com/bbs2/index.php?sho...=302086&hl= After trying several different things it became obvious that several modifications would be necessary to make this combination work. First I disassembled the throttle hand lever assembly and cut the new throttle hand lever. Then I flipped the top portion of the lever around 180 degrees and welded it back together and put a little silver paint on the weld to prevent rust. I reassembled the throttle lever assembly and installed it back into the car. The next two pictures show the lever at both extremes of travel. Next I had to disassemble the console and slot the support bracket to allow enough travel clearance for the modified throttle lever. The slot centerline is 1-3/4” over from the left side of the bracket and is 3/8” wide. I fabricated two brackets to mount the center console. The modified console support bracket is reinstalled 1-1/4 inches forward of its original location. A new lower horizontal board needs to be fabricated. It is 1-3/8 inches longer than the original one was. The vertical gauge board is now more upright than before so that accounts for the 1/8” difference. I think it came out looking close to what the factory would have done if it had offered this option. A special thanks Mark at 914 Rubber for providing the vinyl I needed to fabricate the new longer lower board. Jeff B |
wes |
Mar 6 2017, 07:01 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
Great job well done looks like it belongs there!
Lo-Fi Version | Time is now: 3rd May 2024 - 08:41 AM |
