1970 Porsche 914 vintage race car $10,000 (SOLD!), 1970 Porsche 914 race car |
Bill's Racing 914 |
Mar 5 2017, 02:46 PM
Member Group: Members Posts: 61 Joined: 2-March 14 From: Southern California Member No.: 17,064 Region Association: None |
This car has been sold.......
New BMW 320i front brake calipers New Porsche 911 rear calipers by PMB Performance New stock 914 rear rotors drilled and five studs added by PMB Performance Stock 914 front rotors drilled and tapped to 5 bolt pattern New 19mm master cylinder New lower front ball joints New Coil over Bilstein racing shocks in the rear. New Dual downdraft Weber 40 IDF carbs New 901 mechanical advance distributor New Autometer racing tachometer with shift light New Tangerine Racing full roll cage New Holley racing fuel pump and regulator New 5 point harness New Turbo tie rods New 5lb FE fire system installed New Oil temp gauge New rear wheel bearings Lightweight Porsche 944 cookie-cutter wheels Front adjustable sway bar and rear stock sway bar 15 gal ATL fuel cel Side shift transmission All new shift linkage bushings Kerry Hunter racing headers with Supertrap exhaust. Front mounted RX-7 aluminum oil cooler with steel braided oil lines Custom fiberglass oil cooler shroud Fiberglass hood. Fiberglass front and rear bumpers Custom fiberglass windshield valence Kirkey 17" race seat This car comes with a stock 1.7L Porsche engine ready to take on the track for track days and racing. I still have the windshield frame if you want to have it welded back on. Spares: Two core engines. One is complete and the other is in pieces. One set of 5 lug phone dial wheels Lightened flywheel $10,000 OBO cash or Paypal only Car is located in Ridgecrest, CA (IMG:style_emoticons/default/biggrin.gif) Attached thumbnail(s) |
Lo-Fi Version | Time is now: 29th March 2024 - 12:37 AM |
