WTB Working Decel Valve, D-Jet, 2.0 |
BeatNavy |
Mar 5 2017, 03:28 PM
Looking for a reasonably priced, functioning deceleration valve for D-Jet. I think they're all the same for D-Jet.
Gracias. |
mramber |
Mar 5 2017, 03:31 PM
Member Group: Members Posts: 87 Joined: 14-April 13 From: Minneapolis, MN Member No.: 15,768 Region Association: Upper MidWest |
BeatNavy |
Mar 5 2017, 04:36 PM
I'm pretty sure that's a fuel pressure regulator. The decal valve has three ports.
Do you still have that? Thanks! |
GregAmy |
Mar 5 2017, 04:59 PM
Advanced Member Group: Members Posts: 2,284 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I'm in to snag a second one once Rob gets his.
mramber |
Mar 5 2017, 06:17 PM
I just re-checked my pile of parts and I don't see a decal valve. Sorry guys.
mgphoto |
Mar 6 2017, 08:37 PM
"If there is a mistake it will find me" Group: Members Posts: 1,338 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Check with Bruce Stone, he should has some...
bdstone914 |
Mar 7 2017, 07:03 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
BeatNavy |
Mar 7 2017, 07:40 AM
Yeah, you know I think I managed to get mine working, although I'd still be interested in purchasing one. I could also let Greg get one first if he is sure he needs one.
I tested it as follows: with vacuum pump attached to the control port (the smallest diameter outlet), pull a vacuum up to 25 psi. While you're pulling that vacuum, blow on the side port. At some point above 17 or 18 psi (depending on adjustment) you should be able to blow air through that side port and out the other end port. Below that you won't be able to force air through it. It tastes awesome after you've been soaking it with penetrating oil... (IMG:style_emoticons/default/blink.gif) |
GregAmy |
Mar 7 2017, 08:53 AM
It tastes awesome after you've been soaking it with penetrating oil... (IMG:style_emoticons/default/blink.gif) Hah! I did just that last night...went to bed with the taste of PB Blaster in my mouth... I found a decel in the bottom of my Box O Parts yesterday, and after adjusting it waaaay out it moves at 17 inHg. Going to install and see if it works but I'll keep this thread in mind if it doesn't work. |
Lo-Fi Version | Time is now: 3rd May 2024 - 10:20 PM |
