WTB Working Decel Valve, D-Jet, 2.0 |
BeatNavy |
Mar 5 2017, 03:28 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Looking for a reasonably priced, functioning deceleration valve for D-Jet. I think they're all the same for D-Jet.
Gracias. |
BeatNavy |
Mar 7 2017, 07:40 AM
Yeah, you know I think I managed to get mine working, although I'd still be interested in purchasing one. I could also let Greg get one first if he is sure he needs one.
I tested it as follows: with vacuum pump attached to the control port (the smallest diameter outlet), pull a vacuum up to 25 psi. While you're pulling that vacuum, blow on the side port. At some point above 17 or 18 psi (depending on adjustment) you should be able to blow air through that side port and out the other end port. Below that you won't be able to force air through it. It tastes awesome after you've been soaking it with penetrating oil... (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 11:38 PM |
