WTB Side shift rear shaft and coupler, Side shift rear coupled & shaft |
lvnzdrm |
Mar 5 2017, 05:56 PM
Member Group: Members Posts: 126 Joined: 30-January 13 From: Virginia Member No.: 15,452 Region Association: MidAtlantic Region |
Posting for a friend. He needs the rear shift shaft and swivel joint. His has been welded together and the bushings are missing. Any help is appreciated here is a picture of what he has.
Thanks in advance Jon Attached thumbnail(s) |
euro911 |
Mar 5 2017, 06:51 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Bushings are replaceable - just have to carefully press the center pin out, and carefully pressing it back in when installing the new bushings.
lvnzdrm |
Mar 5 2017, 07:04 PM
Shouldn't the coupler slide out of the rear shaft?
boxstr |
Mar 9 2017, 04:38 PM
Have your friend pm me if he still needs this part.
Craig at CAMP Attached thumbnail(s) |
ndfrigi |
Mar 9 2017, 06:43 PM
rgalla9146 |
Mar 11 2017, 03:44 PM
Posting for a friend. He needs the rear shift shaft and swivel joint. His has been welded together and the bushings are missing. Any help is appreciated here is a picture of what he has. Thanks in advance Jon Hey Jon....I think you're mistaken about what you need. The pin that goes through the bushings IS removable. It is a tight fit but it will press out. So.... press it out...replace bushings...carefully press pin back in. Nothing slides out of the rear shaft. The weld you see is original. |
euro911 |
Mar 11 2017, 10:40 PM
How many times does it need to be said?
Pelican sells the bushings and they're relatively cheap $ T H O M A S made me some bronze shift coupler bushings before he went back to Germany ... I'll never have to replace them again (IMG:style_emoticons/default/mueba.gif) |
Lo-Fi Version | Time is now: 23rd April 2024 - 06:09 PM |
