Wow, you guys ROCK!, Hot start issue on the FAT Performance Rebuild |
Minerva's 914 |
Mar 9 2017, 09:56 PM
Member Group: Members Posts: 378 Joined: 24-December 15 From: Chapel Hill, NC Member No.: 19,489 Region Association: South East States |
I have spent the past several hours going thru the threads on CHT Rich / Lean and Hot Start issues from my search on "Hot Start". I am very impressed with the depth of knowledge and research you guys provided. THANK YOU!!!
My situation results from my first long drive in Minerva's 914 post restoration. There have been several short "test" drives without any noticeable issues, however Sunday evening I drove about 30 miles, at night, with air temperatures in the high 60's. Everything seemed to be wonderful, plenty of power and torque, no noticeable issues, other than one and only one time when I experienced a slight lugging or surging of the engine at just under 3,000 RPMs and I reactively downshifted and thought nothing of it. That being said, maybe there is nothing to this but I want to share everything I can remember about that evening, just in case there might be a fuel pressure issue at fault. When I returned home, I was backing it in the garage slowly since it doesn't have the rearview mirror installed yet, nor did it ever have a righthand mirror when the rear tires bumped up against the rain guard rise going into the garage and stopped. As I engaged the clutch I stalled the engine. I switched off the ignition and back on but the engine spun but did not fired at all. I switched it back off and tried again without success. I turn the ignition off and waited a couple minutes and tried again. Nothing. It had all of the sounds and lack of firing as if it had vapor locked as it did years ago before I relocated the fuel pump to the front. The next day and every time since it starts immediately and runs perfectly. I have not yet taken it back out for a long drive. FAT Performance in CA built the engine with slightly oversized jugs and I remember them saying that I may have to increase the fuel pressure to work with the new engine but I didn't go into any more details about that at that time. I plan to call them tomorrow and ask if that might be something I want to address, even if it doesn't have anything to do with this issue. I'll also call John at Black Forest for his input. So, I'm thinking that this weekend I should check the fuel pressure, check the CHT sensor and confirm all of the state of tune. Can you guys suggest anything else or contribute opinions / thoughts on this? The fact that it was a relatively cool evening and the engine did not have time to change temperature relative to the sensor does not seem to be all that similar to the issues others have written about here. Opinions PLEASE. And thank you in advance. |
r_towle |
Mar 10 2017, 09:09 AM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Slightly larger pistons?
Please be more specific. If you are running the stock fuel injection, you need to search for how to re calibrate your MPS to deliver the new required amount of fuel. Increasing the fuel pressure won't do it, FAT is wrong there. a few guys here offer the service to re calibrate your MPS to match your needs....find them. If you run too lean, the motor will be really hot and burn up the valves and worse. you need to get some gauges to see what is up with your setup. Too little fuel ==== to much heat too much advance on timing ==== too much heat. Heat will kill the motor. rich |
Minerva's 914 |
Mar 10 2017, 11:12 AM
Slightly larger pistons? Please be more specific. If you are running the stock fuel injection, you need to search for how to re calibrate your MPS to deliver the new required amount of fuel. Increasing the fuel pressure won't do it, FAT is wrong there. a few guys here offer the service to re calibrate your MPS to match your needs....find them. If you run too lean, the motor will be really hot and burn up the valves and worse. you need to get some gauges to see what is up with your setup. Too little fuel ==== to much heat too much advance on timing ==== too much heat. Heat will kill the motor. rich Makes perfect sense! The motor seemed to me to be too lean to start and not too rich, as it would be if the sensor was the issue. I called FAT but they are closed on Fridays but I have their receipt boxed up with my paper work (we're in the process of moving) and I'll try to find it this weekend and call FAT again on Monday. Btw, it's been almost 3 years since they finished the engine and due to the local "In By Noon, Out By June" shop falling down on the install I'm sure FAT would have said "adjust the MPS to match" and not as I remember "adjust the fuel pressure". Once I get the correct info, I'll talk to John at Black Forest Racing to see if he can properly map my set-up. THANK YOU!!! |
Lo-Fi Version | Time is now: 19th May 2024 - 10:40 PM |
