Boring cylinders, Stock 2.0L |
jeffdon |
Mar 11 2017, 12:17 PM
How large can you go when boring out stock 2.0L cylinders? And what pistons would work at that size? If you kept the stock rods, what would the new displacement be?
Mark Henry |
Mar 11 2017, 01:20 PM
96mm, use KB pistons, stick with a proven combo.
Mar 11 2017, 02:47 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
with custom pistons you could go to 98MM but it would cost quite a bit.
with 96mm it would be 2056, and like mark said its a common combo, proven to work well, but you will need to get your MPS adjusted. rich |
Lo-Fi Version | Time is now: 22nd May 2024 - 10:06 AM |
