What's your A/F on Overrun?, 'Nother D-Jet A/F Question |
BeatNavy |
Mar 12 2017, 12:28 PM
For those with D-Jet, what are you typically seeing for A/F ratio on a medium to hard overrun? Based on what I've read here mine seems too rich - like in 10's and 11's. Once the RPM's drop closer to idle it bounces back up to normal idle A/F ratios. Does A/F on overrun even matter?
Mark Henry |
Aug 15 2017, 08:11 AM
Olympic 914 |
Aug 15 2017, 09:23 AM
Group: Members Posts: 1,668 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Does A/F on overrun even matter? Overrun and AFR means diddly squat. No load, it doesn't matter how lean it is. I have complete fuel cut on my programmable FI, you can't get leaner than that, it's never hurt anything. If it were lean I wouldn't worry about it, but its real rich in the 10.0 + range. So somehow it is dumping fuel in there. it may even be worse but my low reading limit on the Autometer AFR is set a 10.0 granted I have not put many miles on this engine and am still sorting things out but after following a truck down a long hill with it going rich, when the truck stopped at the bottom of the hill to make a turn and I had to stop behind it, the engine just quit... it did start right up again, but since I am looking for problems this might be one. Engine is a 2056 w/ Raby 9590 cam and Ham's RS+ heads, SS HEs and a Triad muffler. ECU 037 |
Mark Henry |
Aug 15 2017, 11:31 AM
Does A/F on overrun even matter? Overrun and AFR means diddly squat. No load, it doesn't matter how lean it is. I have complete fuel cut on my programmable FI, you can't get leaner than that, it's never hurt anything. If it were lean I wouldn't worry about it, but its real rich in the 10.0 + range. So somehow it is dumping fuel in there. it may even be worse but my low reading limit on the Autometer AFR is set a 10.0 granted I have not put many miles on this engine and am still sorting things out but after following a truck down a long hill with it going rich, when the truck stopped at the bottom of the hill to make a turn and I had to stop behind it, the engine just quit... it did start right up again, but since I am looking for problems this might be one. Engine is a 2056 w/ Raby 9590 cam and Ham's RS+ heads, SS HEs and a Triad muffler. ECU 037 Oh sorry, brain fart...guess I should read things better. (IMG:style_emoticons/default/smile.gif) My first guess is it isn't dumping any more fuel in, just you cut off the air so it makes the charge rich. I'd say it doesn't have any fuel cut at all, I don't know if that is normal for D-jet or not. I do know L-jet definitely has a fuel reduction, but not a total fuel cut. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:21 AM |
