What's your A/F on Overrun?, 'Nother D-Jet A/F Question |
BeatNavy |
Mar 12 2017, 12:28 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
For those with D-Jet, what are you typically seeing for A/F ratio on a medium to hard overrun? Based on what I've read here mine seems too rich - like in 10's and 11's. Once the RPM's drop closer to idle it bounces back up to normal idle A/F ratios. Does A/F on overrun even matter?
BeatNavy |
Aug 15 2017, 12:17 PM
My understanding is that the TPS detects an idle situation and then mixture is controlled by ECU idle settings, not by MPS. Some ECU's cut fuel off above certain RPM on idle, although I can't remember which ECU models off hand. But I'm not going lean, I'm going rich. Mark's explanation about less air would make sense. But that would indicate a fairly normal operation, right? I was under the impression that most people see pretty lean conditions on overrun.
Lo-Fi Version | Time is now: 18th May 2024 - 11:56 PM |
