What's your A/F on Overrun?, 'Nother D-Jet A/F Question |
BeatNavy |
Mar 12 2017, 12:28 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
For those with D-Jet, what are you typically seeing for A/F ratio on a medium to hard overrun? Based on what I've read here mine seems too rich - like in 10's and 11's. Once the RPM's drop closer to idle it bounces back up to normal idle A/F ratios. Does A/F on overrun even matter?
BeatNavy |
Aug 15 2017, 12:17 PM
My understanding is that the TPS detects an idle situation and then mixture is controlled by ECU idle settings, not by MPS. Some ECU's cut fuel off above certain RPM on idle, although I can't remember which ECU models off hand. But I'm not going lean, I'm going rich. Mark's explanation about less air would make sense. But that would indicate a fairly normal operation, right? I was under the impression that most people see pretty lean conditions on overrun.
914_teener |
Aug 15 2017, 12:36 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
My understanding is that the TPS detects an idle situation and then mixture is controlled by ECU idle settings, not by MPS. Some ECU's cut fuel off above certain RPM on idle, although I can't remember which ECU models off hand. But I'm not going lean, I'm going rich. Mark's explanation about less air would make sense. But that would indicate a fairly normal operation, right? I was under the impression that most people see pretty lean conditions on overrun. I believe the overun or "with overun cut off circuit" are listed on Brad Anders site in his part description matrix. I think it.s function is three fold. Driveability, emissions, and fuel economy. I know I have it on my car. You can actually feel it when coasting to a stop when the tps hits the cut off. That is.....when it is adjusted right. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:26 AM |
