FS: Oil pump, cam bearings, oil pressure relief piston |
rtalich |
Mar 13 2017, 10:39 AM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
Oil pump is a 30mm modified for full flow, comes with a limited edition Type I Killers RAT pump cover and Tool Steel intermediate plate - $80 for the set.
Single thrust Mahle Cam Bearings - $30 for the set. Not pictured, I have a stock Oil Pressure Relief Piston with Spring - $5 or free if you buy the oil pump set :-) Thanks, Rob Attached thumbnail(s) |
rtalich |
Mar 14 2017, 09:59 AM
bump... open to reasonable offers
rtalich |
Mar 20 2017, 10:58 AM
Oil pump is a 30mm modified for full flow, comes with a limited edition Type I Killers RAT pump cover and Tool Steel intermediate plate - Single thrust Mahle Cam Bearings - Not pictured, I have a stock Oil Pressure Relief Piston with Spring - Thanks, Rob Price adjustments... |
rtalich |
Mar 21 2017, 12:41 PM
SOLD
Lo-Fi Version | Time is now: 17th April 2024 - 03:18 PM |
