Water Cooled 914 Help, Air in the system |
Mowog4 |
Mar 13 2017, 08:51 PM
Member Group: Members Posts: 277 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
I am getting ready to fire up my Subie powered 914, and am looking for some suggestions of how people have run the water lines for their heater. I am running a Renegade cooling system, with a cowl mounted heater core. I am assuming I will run a 5/8 tees in the upper and lower hoses, thought I would see if anyone had any pictures before I started.
Thanks, Ed |
Mike Bellis |
Mar 13 2017, 09:05 PM
I ran mine in the long through the original heater tube. Pretty easy install.
Andyrew |
Mar 13 2017, 09:07 PM
About 90% of the conversions run the lines under the car in the reliefs in the floorpan.
Mike Bellis |
Mar 13 2017, 09:32 PM
Mowog4 |
Mar 13 2017, 09:34 PM
I am running Gates hoses under the car back to the engine, I am trying to figure out a clean way of running heater hoses, the heater core is in the cowl.
Chris914n6 |
Mar 13 2017, 10:40 PM
Jackstands are my life. Group: Members Posts: 3,287 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
76-914 |
Mar 14 2017, 02:43 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,454 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I ran mine in the long through the original heater tube. Pretty easy install. (IMG:style_emoticons/default/agree.gif) |
Andyrew |
Mar 14 2017, 04:32 PM
Ed,
Can you show us a picture of your cowl mounted heater core? |
Gmanscott55 |
Mar 14 2017, 06:34 PM
Member Group: Members Posts: 182 Joined: 3-February 16 From: Sunset Beach,Ca Member No.: 19,630 Region Association: Southern California |
Hey Ed... Glad you are getting close to finishing. Post up some pics when all done.
Gary in Sunset Beach |
Mowog4 |
Mar 15 2017, 01:12 AM
Hey Ed... Glad you are getting close to finishing. Post up some pics when all done. Gary in Sunset Beach Hey Gary, how are you and one of my all time favorite 914's doing? I am close to driving, this making a living thing really interferes with my toy car projects. Hopefully a couple of weeks |
Mowog4 |
Mar 15 2017, 11:21 PM
Ed, Can you show us a picture of your cowl mounted heater core? Here are some pics: The AC Evap/heater core mounts in the cowl, the blower motor mounts behind the dash (I am going to have to modify the glove box). The vents will be defroster, factory vents in the lower dash panel, and a couple of vents in the center console. I haven't run freon or hot water through the core yet, but the blower puts out plenty of air in the initial tests. It is the ugly black color because I coated the evap box with lizzard skin thermal coat. |
JRust |
Mar 16 2017, 08:46 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I don't have pics but just put a "T" in my radiator hoses under the gas tank. Shortest way to run them & mine worked great. Until I pulled it to put in A/C (IMG:style_emoticons/default/dry.gif)
Mowog4 |
Mar 16 2017, 11:47 PM
I don't have pics but just put a "T" in my radiator hoses under the gas tank. Shortest way to run them & mine worked great. Until I pulled it to put in A/C (IMG:style_emoticons/default/dry.gif) Where did you put your AC evaportator? |
bulitt |
Mar 17 2017, 06:36 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Andyrew |
Mar 17 2017, 08:14 AM
Ed, Can you show us a picture of your cowl mounted heater core? Here are some pics: The AC Evap/heater core mounts in the cowl, the blower motor mounts behind the dash (I am going to have to modify the glove box). The vents will be defroster, factory vents in the lower dash panel, and a couple of vents in the center console. I haven't run freon or hot water through the core yet, but the blower puts out plenty of air in the initial tests. It is the ugly black color because I coated the evap box with lizzard skin thermal coat. I like it! Which model kit did you use? I have something similar but its not separate like that, the blower and heater core are in one system. Did you custom make that? |
Mowog4 |
Mar 17 2017, 10:56 AM
Ed, Can you show us a picture of your cowl mounted heater core? Here are some pics: The AC Evap/heater core mounts in the cowl, the blower motor mounts behind the dash (I am going to have to modify the glove box). The vents will be defroster, factory vents in the lower dash panel, and a couple of vents in the center console. I haven't run freon or hot water through the core yet, but the blower puts out plenty of air in the initial tests. It is the ugly black color because I coated the evap box with lizzard skin thermal coat. I like it! Which model kit did you use? I have something similar but its not separate like that, the blower and heater core are in one system. Did you custom make that? I took an Old Air Products underdash AC/Heat kit and tried to make it work. I even went so far as to notch my Gas Tank and try to put it where the fresh air blower is. My biggest concern was how to pull the air from inside the car to the unit. I ended up scrapping the unit, pulled the evaporator core out of it and built a 4" X 4"X 15" Aluminum box to house the evaporator. Then I mounted the blower motor on the inside firewall behind the glove box. The theory being it will pull air from the cabin, giving me recirculated air which should be more effecient. In my quest for slightly better than mediocrity, the blower unit which came on the Old Air Unit was a Spal knock off which put out about 165CFM. I instead went with a genuine SPAL unit 008-A45-02 which put out closer to 300. It blows into the evap box, which I insulated with Lizzard Skin Ceramic coating, and then routes to the defroster, center console, and side vents. I am expecting to control it from the factory blower, heat and defroster control. There will be a button in the center console which engages the compressor. I have tried a bunch of combinations,I think this is going to work pretty well. |
Mowog4 |
Mar 20 2017, 11:00 AM
After a particularly long airline flight where I had way too much time online, I bought this coolant sight glass. I am thinking it would be useful to have it, I am thinking i till put it in line with the upper radiator hose. Make sense?
Lo-Fi Version | Time is now: 28th March 2024 - 09:50 AM |
