> Bleeding Bleeding Bleeding AIR???, give me a quick hand ...
RangerRhett
post May 4 2005, 09:13 PM
I started to bleed the brakes tonight.
I know the order:
Right Rear
Left Rear
Right Front
Left Front
Even when I started, I was getting bubbles in my hand pump (with cannister) . Now I get no, zero resitance on the brake Pedal. None...Zero...
Should I close up all the nipples, push on the pedal a few times and then start over....repeat, repeat, repeat until I get a steady stream of brake fluid...?
'Lil Help on this one..
RangerRhett   Bleeding Bleeding Bleeding AIR???   May 4 2005, 09:13 PM
SLITS   Did the MC run dry at any time? Crack the connect...   May 4 2005, 09:16 PM
914fire   As long as you have air in your lines your going t...   May 4 2005, 09:17 PM
xsboost90   did mine the other nite. filled resevoir, closed b...   May 4 2005, 09:18 PM
RangerRhett   The Reservoir was always full...When I would take ...   May 4 2005, 09:19 PM
bondo   Those mityvac brake bleeders work in a pinch but t...   May 4 2005, 09:20 PM
Andyrew   You opened up all the valves at the same time? Wha...   May 4 2005, 09:21 PM
SLITS   Just crack the connections at the MC and let it gr...   May 4 2005, 09:23 PM
RangerRhett   There is no way the MC is bad...it was working gre...   May 4 2005, 09:26 PM
Dave Blackburn   I have a vacuume bleeder and have had a few proble...   May 4 2005, 09:26 PM
RangerRhett   Guys, How do I get the fluid back through the bra...   May 4 2005, 09:33 PM
914fire   pump pump pump.....   May 4 2005, 09:35 PM
RangerRhett     May 4 2005, 09:35 PM
Thorshammer   Slits is right, crack the master cylinder and let ...   May 4 2005, 09:51 PM
trekkor   Good thread. I'll be doing this shortly mysel...   May 4 2005, 10:08 PM
sgomes   I know every time we have one of these brake bleed...   May 4 2005, 10:27 PM
914GT   Here are a couple of tips for good brake bleeding ...   May 4 2005, 10:30 PM
!   S P E E D B L E E D E R S   May 4 2005, 10:38 PM
914GT
- Lo-Fi Version Time is now: 4th July 2025 - 04:57 AM
