How to re-wire the Head Tempature Sensor after EFI, 1974 2.0 converted to carb |
NJTom |
Mar 18 2017, 09:14 AM
Member Group: Members Posts: 92 Joined: 16-July 14 From: NJ Member No.: 17,643 Region Association: None |
Hi we are getting ready to install a 1974 2.0 with a carburetor but don't know what to do with the Tempature Sensonr wire that comes from the motor. We found it in the EFI harness. Is there a way to directly wire and if so where does it go? Thanks in advance!
Attached thumbnail(s) |
Mark Henry |
Mar 18 2017, 09:30 AM
I do hope you mean carburetors, as it two...
The only way to be sure a single carb works proper is to test the float. Toss the carb in a lake and if it floats it's good to use. The temp sensor is only for the FI, remove it, tuck it away or snip the wire off. |
brant |
Mar 18 2017, 09:38 AM
914 Wizard Group: Members Posts: 11,622 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The cht wire you identified does not send signal to a gauge. Only to the fi brain. You don't need it with carbs
If you run a cht gauge there is a seperate wire under a spark plug for that signal |
kkid |
Mar 19 2017, 12:40 PM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
Don't cut the wire. Just loosen and remove it. It's not a cheap part. You should store it for your future use or give it to me (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 8th May 2024 - 03:49 PM |
