What's the best hand cleaner |
Porschef |
Mar 19 2017, 11:22 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
This may not answer your question but i thought it worth mentioning. My father worked on cars and other mechanical devices for most of his life, he had some medical issues and when they looked at his liver he was told about damage done most probable cause is thought to be exposure to chemicals (solvents and oils) over the years. My take away was to get used to wearing gloves. Agreed 100%. I read through this thread earlier, but hadn't an opportunity to reply. Your skin is an organ, it's there to protect you and keep all the important stuff inside, and the bad stuff out. When I researched the cause of my extremely rare lymphoma, the primary culprit is exposure to chemicals. This would make sense, as I worked in the printing field for a number of years. Inks, solvents, washes, etc. were commonly encountered on a daily basis. Throw in auto work, oil changes, and any number of other evils, and there you have it. Needless to say, I'm never without a case of nitrile gloves. I don't want to quit wrenching, but I do want to limit my exposure to nasty stuff that might retrigger any relapse. Bottom line, learn to live with the gloves, ventilate your work area, and do your best to eliminate or at least, cut down on your exposure to compounds. If you need to clean after, Boraxo does work well, as Rory suggested. Just my .02 Joe |
rgalla9146 |
Mar 19 2017, 05:48 PM
This may not answer your question but i thought it worth mentioning. My father worked on cars and other mechanical devices for most of his life, he had some medical issues and when they looked at his liver he was told about damage done most probable cause is thought to be exposure to chemicals (solvents and oils) over the years. My take away was to get used to wearing gloves. Agreed 100%. I read through this thread earlier, but hadn't an opportunity to reply. Your skin is an organ, it's there to protect you and keep all the important stuff inside, and the bad stuff out. When I researched the cause of my extremely rare lymphoma, the primary culprit is exposure to chemicals. This would make sense, as I worked in the printing field for a number of years. Inks, solvents, washes, etc. were commonly encountered on a daily basis. Throw in auto work, oil changes, and any number of other evils, and there you have it. Needless to say, I'm never without a case of nitrile gloves. I don't want to quit wrenching, but I do want to limit my exposure to nasty stuff that might retrigger any relapse. Bottom line, learn to live with the gloves, ventilate your work area, and do your best to eliminate or at least, cut down on your exposure to compounds. If you need to clean after, Boraxo does work well, as Rory suggested. Just my .02 Joe I agree with you Joe about solvents. Your comments about our skin being an organ is correct, in fact it is our largest organ. Can't wait for the colorful comments. |
Bartlett 914 |
Mar 19 2017, 05:57 PM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
My Father in law is a retired tool and die maker. Working with solvents he developed an allergy to petroleum products. He found Mean Green hand scrub is perfect. I get it by the 5 gal pail. I take it everywhere. It has no petroleum products in it. It has lanolin. There are fine plastic beads that do the scrubbing. Lava is sharp and wears at the skin. I cannot recommend a better soap!
Mean Green hand soap |
Amphicar770 |
Mar 19 2017, 06:03 PM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Gojo (woman in a can) seems to work best but as others have said, gloves are your best bet.
AndyB |
Mar 19 2017, 06:09 PM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
Dawn and a vegetable scrubber.
AndyB |
mbseto |
Mar 20 2017, 07:56 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Olive oil will lift grease and motor oil right off your hands. Just rubs off, no real scrubbing needed. Then just use any hand soap to clean the olive oil off. Any cooking oil will work, canola, vegetable, whatever floats your boat.
colingreene |
Mar 20 2017, 11:46 AM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
I use Loyal hand cleaner.
burton73 |
Mar 20 2017, 12:03 PM
burton73 Group: Members Posts: 3,503 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I have been in the Plastic Casting Business for 42 years. Our hands have been in polyester resin for a large part of that. We always use gloves.
Before I went into the plastic business, I wanted to be a printer. That was back in 1972. My father sent me to his friend that was a printer and he told me that I did not want to go in the business because at that time you had to clean up the presses with solvent and he showed me his hands. He straitened out his hand and they started to bleed. Than was all it took. I changed my option on what I wanted to do. I am 64 now and just mixed up some resin in the vent cabinet with gloves on. Back is bad but I am here still. Bob |
cwpeden |
Mar 20 2017, 12:26 PM
Regular dish soap and a tsp of Sugar for grit.
Don't substitute Salt, unless you want to find where your cuts are? |
KELTY360 |
Mar 20 2017, 12:29 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
I'm not comfortable wearing gloves and so every time I work on the engine, I get nasty fingers. The orange stuff just doesn't work well enough. Anybody have a better product? Gojo Original Formula - Hand Cleaner I got some Gojo Original Formula - Hand Cleaner today at O’Reillys and this is not the stuff with the Pumice, and it completed dissolved the dirt and oil and left my hands very soft without the oily feel and not the dried out san paper feel of pumice stuff. Bob (IMG:style_emoticons/default/agree.gif) But I also use nitrile gloves that I bought at Costco. They are cheap enough that you can feel comfortable using them for small, quick jobs and throwing them out. |
7TPorsh |
Mar 20 2017, 12:35 PM
toothpaste and a toothbrush works as well....
11tenths |
Mar 20 2017, 01:23 PM
Ve get too soon old, und too late schmart Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States |
Plain old Wesson Oil will dissolve the grease, then wipe off with a paper towel or vegetable scrub brush for the fingernails. Follow this with Dawn dish washing soap and hot water and you're done... (IMG:style_emoticons/default/clap56.gif)
-Harry |
jd74914 |
Mar 20 2017, 01:56 PM
Its alive Group: Members Posts: 4,778 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
There is a product called "Scrubs in a bucket" that is simply the best in my opinion. They're somewhat elusive, as I never seen them for sale in a retail store but you may find them at a HVAC supply house or online. These wipes work amazingly well. Every time I let someone try these, they always fall in love with them. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) They are awesome! I'd never used them until last summer when I picked up a motor from a guy on Craigslist who had a bucket. They literally lift hard grime right off your hands. Like other people. I try to wear disposable gloves, but there are just some times when it's impractical, they keep ripping, etc. |
6freak |
Mar 20 2017, 02:30 PM
I'm not comfortable wearing gloves and so every time I work on the engine, I get nasty fingers. The orange stuff just doesn't work well enough. Anybody have a better product? you just got that car 95% done where s all the dirt coming from ....mines still clean as a pin top and bottom...oil leak? (IMG:style_emoticons/default/smile.gif) |
Mark Henry |
Mar 20 2017, 04:34 PM
Clean with LA Totally Awesome, a bit more scrubbing, but your hands are nice and clean. Yellow stuff, I mix it 4 to 5:1, non flammable, very low on the WHMIS hazard scale even by California standards. Slight skin irritant but just wash it off, I do notice it's a slight irritant if you breath it in so I avoid doing that, I believe this is caused by the citrus. Doesn't attack gloves, I use full strength in a spray bottle for heavy stuff.
You wash it off with water, but parts don't seen to flash rust. Slightly caustic so don't leave aluminum parts in it for days on end. If you don't wash it off right away, or do a poor job washing it off, it seems to leave a white powdery residue but it wipes off and doesn't seem to hurt anything. I'm running it in my parts washer, dirt cheap so I change it often. I dump the old stuff into a small barrel with a lid and use it to pre-wash before parts go into the parts washer. I buy it by the case. I use Canadian Tire brand hand cleaner, like gojo but way better. Plus wash the dishes by hand, the wife will love you and it does a good job on your hands. |
Cairo94507 |
Mar 20 2017, 04:56 PM
Michael Group: Members Posts: 9,714 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I buy the powder free gloves by the case and split them with my brother. I don't even wax my car or wipe it down without gloving up. It saves your hands from looking like you wrench 24/7. I usually wear a suit to work and if my hands were dirty, that would not be a good thing (for me).
I had never considered the chemical exposure, but that is one hell of a good reason to gloves up too. Life ages you quickly enough with out helping that along with unnecessary chemical exposure. |
Mark Henry |
Mar 20 2017, 05:00 PM
slotty008 |
Mar 20 2017, 05:02 PM
Member Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None |
I like the orange stuff with the pumice in it followed up by Dawn dish washing soap and a brush. That's what I used for the 10 years that I owned my garage. Washing the dishes also helped get them really clean. I would only use gloves when I used the parts cleaner or packing wheel bearings with grease. The parts cleaning solution was tough on the skin and I could never stand grease on my hands. I find it difficult to start a nut or bolt with gloves on. A friend in the Porsche Club once told me that he wished he could work on his own car the way that I do. I asked why not? His response was I'm a Dentist. Charlie I'm a dentist too and I always use nitrile gloves (the same as in my practice); Hundreds of them! They cost about 11$ for a hundred.They don't last long but you can do very fine work with them. I wear them 10 hours a day when I'm working. You don't feel them if you can find a brand that really fits your hand. |
My 914 |
Mar 20 2017, 08:54 PM
Casual Member Group: Members Posts: 560 Joined: 23-April 16 From: Massachusetts Member No.: 19,928 Region Association: North East States |
You don't realize how many chemicals get absorbed through your skin. They're not only bad for your hands with the skin damage they cause, but (as other posts said), they can also cause damage elsewhere in the body.
Gloves are far and away the best solution. They take time to learn to put on, take off and use during work, but worth the investment. When you take off a pair of gloves that you wore when working say, with a set of tires, you have to wonder about all that grime not being on your hands. All the soap and scrub you use will not take it off completely! |
Lo-Fi Version | Time is now: 26th April 2024 - 04:25 PM |
