914-6 oil tank dw design, is the oil filler attached with a hose??? |
914dave |
Mar 18 2017, 04:11 PM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
i'm installing my dw design oil tank in my conversion. i have the filler neck from Rebel racing dipstick and cap included. It looks like there should be a hose that slides over the filler neck and the tank neck. Can someone post pics of their's?
thanks Dave |
Mark Henry |
Mar 18 2017, 05:26 PM
If the stock tank does use a hose I know for sure the DWD tank will use the exact same hose, every connection on the DWD tank is stock spec.
I'm sure that the stock tank uses this hose, but I can't find a part number. You can go to the DWD design web site and email Don, he doesn't build tanks anymore, but he's happy to answer questions about them. Let us know what he says, I need the same hose for my DWD tank. (IMG:style_emoticons/default/smile.gif) |
914dave |
Mar 18 2017, 05:30 PM
If the stock tank does use a hose I know for sure the DWD tank will use the exact same hose, every connection on the DWD tank is stock spec. I'm sure that the stock tank uses this hose, but I can't find a part number. You can go to the DWD design web site and email Don, he doesn't build tanks anymore, but he's happy to answer questions about them. Let us know what he says, I need the same hose for my DWD tank. (IMG:style_emoticons/default/smile.gif) Will do. I'll postt when I find out. Thanks |
Steve |
Mar 18 2017, 05:38 PM
914 Guru Group: Members Posts: 5,568 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
The hose on the filler neck either goes to a puke bottle or into the rubber boot that the airflow meter goes into. On carb motors it goes into the aircleaner.
The only other breather hose is the one on the tank. It goes to the motor. The pictures below are out of the Porsche 914 Clymer manual. They still sell it at Pelican |
914dave |
Mar 18 2017, 05:41 PM
The hose on the filler neck either goes to a puke bottle or into the rubber boot that the airflow meter goes into. On carb motors it goes into the aircleaner. The only other breather hose is the one on the tank. It goes to the motor. The pictures below are out of the Porsche 914 Clymer manual. They still sell it at Pelican Steve I'm looking for the hose to connect the filler neck to the tank. Thanks for the pics. Dave |
rgalla9146 |
Mar 18 2017, 05:57 PM
Hey Dave
It's a Norma clamp, marked simply '54' it's wide though maybe 1.25 " Attached image(s) |
Steve |
Mar 18 2017, 06:31 PM
I bought mine directly from Porsche back in 1986. I don't know if they still sell it.
Mar 18 2017, 06:33 PM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The hose on the filler neck either goes to a puke bottle or into the rubber boot that the airflow meter goes into. On carb motors it goes into the aircleaner. The only other breather hose is the one on the tank. It goes to the motor. The pictures below are out of the Porsche 914 Clymer manual. They still sell it at Pelican Steve I'm looking for the hose to connect the filler neck to the tank. Thanks for the pics. Dave Dave - I tried to find a stock porsche hose, no luck. None of the stock hoses are long enough. Looked for any hose, including radiator hose, no luck, so I took the stock hose and a second one just like it and joined them with a brass fitting from Home Depot and 2 hose clamps. |
914dave |
Mar 18 2017, 06:42 PM
I used a 2" radiator hose with a couple clamps. Thanks for the feedback guys.
rgalla9146 |
Mar 18 2017, 06:45 PM
Hey Dave It's a Norma clamp, marked simply '54' it's wide though maybe 1.25 " Dave the hose is a molded part with collars on each end. Not to say a piece of hose wouldn't work. I'll have the OE part numbers for you in a few..... And the width of the clamp too. |
Mar 18 2017, 06:56 PM
porschetub |
Mar 18 2017, 08:31 PM
Hi Dave ,I have a reduced diameter silicone hose as I have PMS filler assembly so not too much help.
The hose you have will do you fine for a while but keep an eye on it the oil may cause it to crap out,silicone would be better. Check your dipstick after you have put in the required amount of oil for your donor engine while it is warm and running,mine is 7 litres so I added another 1/2 litre and no show on the stick....aftermarket parts eh. |
raynekat |
Mar 18 2017, 09:06 PM
Advanced Member Group: Members Posts: 2,153 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Part no. for the molded rubber is 901.107.691.10
Both Stoddard and Aase have them for $40-45. Might find them cheaper at Sunset Porsche. The clamp is a special one, but one of the same diameter should work. The real one is likely a bit wider than your typical hose clamp. I found a used one and had it re-plated. |
PanelBilly |
Mar 18 2017, 09:26 PM
914 Guru Group: Members Posts: 5,797 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I got mine from an industrial hose and fitting supplier. The kind of place that makes up hydrolic lines for forklifts and dozers. Took the tank and the filler neck in to them.
Larmo63 |
Mar 18 2017, 10:27 PM
I'm using the Patrick Motorsports oil tank in my conversion, but I think I may have that clamp in my pile 'o parts.
914dave |
Mar 19 2017, 05:52 AM
914dave |
Mar 19 2017, 06:15 AM
914dave |
Mar 19 2017, 06:16 AM
mb911 |
Mar 19 2017, 06:36 AM
914 Guru Group: Members Posts: 6,806 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
With our tanks we use a 2 inch silicone coupler for a turbo intercooler applications. I also make out oil fill neck to fit inside the tank and the tank could be clamped down on it if desired. I think the best way really do this would be to use an aluminum v band set up and using 638 loctite to hold the v bands into the respective components.
rgalla9146 |
Mar 19 2017, 07:06 AM
Hey Dave It's a Norma clamp, marked simply '54' it's wide though maybe 1.25 " Rory The 54 is probably mm's for the diameter. Hey Dave Yes, 54 is the clamp diameter in mm The part number is 999 512 073 02 It is described as 54/25 so 25mm width. Will your tank and filler neck work work with OE parts ? Pelican shows it as a good number for $5.75 !! ?? |
Lo-Fi Version | Time is now: 24th April 2024 - 02:50 AM |
