914-6 oil tank dw design, is the oil filler attached with a hose??? |
914dave |
Mar 18 2017, 04:11 PM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
i'm installing my dw design oil tank in my conversion. i have the filler neck from Rebel racing dipstick and cap included. It looks like there should be a hose that slides over the filler neck and the tank neck. Can someone post pics of their's?
thanks Dave |
rgalla9146 |
Mar 18 2017, 05:57 PM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Hey Dave
It's a Norma clamp, marked simply '54' it's wide though maybe 1.25 " Attached image(s) |
914dave |
Mar 19 2017, 06:15 AM
rgalla9146 |
Mar 19 2017, 07:06 AM
Hey Dave It's a Norma clamp, marked simply '54' it's wide though maybe 1.25 " Rory The 54 is probably mm's for the diameter. Hey Dave Yes, 54 is the clamp diameter in mm The part number is 999 512 073 02 It is described as 54/25 so 25mm width. Will your tank and filler neck work work with OE parts ? Pelican shows it as a good number for $5.75 !! ?? |
914dave |
Mar 19 2017, 07:23 AM
Hey Dave It's a Norma clamp, marked simply '54' it's wide though maybe 1.25 " Rory The 54 is probably mm's for the diameter. Hey Dave Yes, 54 is the clamp diameter in mm The part number is 999 512 073 02 It is described as 54/25 so 25mm width. Will your tank and filler neck work work with OE parts ? Pelican shows it as a good number for $5.75 !! ?? It should work with OE parts. $5.75 sounds optimistic. |
Lo-Fi Version | Time is now: 2nd May 2024 - 04:05 PM |
