914-6 oil tank dw design, is the oil filler attached with a hose??? |
914dave |
Mar 19 2017, 07:23 AM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Hey Dave It's a Norma clamp, marked simply '54' it's wide though maybe 1.25 " Rory The 54 is probably mm's for the diameter. Hey Dave Yes, 54 is the clamp diameter in mm The part number is 999 512 073 02 It is described as 54/25 so 25mm width. Will your tank and filler neck work work with OE parts ? Pelican shows it as a good number for $5.75 !! ?? It should work with OE parts. $5.75 sounds optimistic. |
Dion |
Mar 19 2017, 07:38 AM
RN Group: Members Posts: 2,762 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Dave whatever solution you come up with, please double the order.
Since I'll be needing the same for my tank. Thanks bro! Cheers,Dion |
6freak |
Mar 20 2017, 08:05 AM
i'm installing my dw design oil tank in my conversion. i have the filler neck from Rebel racing dipstick and cap included. It looks like there should be a hose that slides over the filler neck and the tank neck. Can someone post pics of their's? thanks Dave should be rubber sleeve thing ,,ya gotta contect um. IIRR its a bitch..good luck (IMG:style_emoticons/default/smile.gif) |
Randal |
Mar 20 2017, 08:10 AM
Mark Henry |
Mar 20 2017, 10:16 PM
The neck is 2 inches, but the barb is .100" bigger so a stiff hose will be damn near impossible to stretch over it. The neck fits into the hole in the tank so it is self supporting.
I'd try to get the silicone or at least a soft stretchy rubber. Same deal on the vent which is one inch. Attached image(s) |
914dave |
Mar 21 2017, 05:49 AM
The neck is 2 inches, but the barb is .100" bigger so a stiff hose will be damn near impossible to stretch over it. The neck fits into the hole in the tank so it is self supporting. I'd try to get the silicone or at least a soft stretchy rubber. Same deal on the vent which is one inch. Mark Good stuff. |
Lo-Fi Version | Time is now: 19th April 2024 - 05:45 AM |
