Starting engine out of car |
N_Jay |
Mar 18 2017, 07:06 PM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
What is the easiest way to start up a 914 engine out of the car.
I have an extra transmission, but seem that just the front part of an old transmission case would take a lot of weight off the whole assembly? (Anyone have such a thing.) I figured a set of short legs on the end on et engine mount bar would be spread far enough apart to be fairly stable. As for the rear, I hadn't got that far in my thinking. What I really wondered if how well it would start and run with no exhaust? I have a 1.8 and a 2.0 that are supposedly complete and want o make sure they actually run before putting one in the car. Each has full factory EFI (D-Jet and L-Jet). I also have an extra relay board, starter, etc. |
rgalla9146 |
Mar 19 2017, 10:17 AM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
What is the easiest way to start up a 914 engine out of the car. I have an extra transmission, but seem that just the front part of an old transmission case would take a lot of weight off the whole assembly? (Anyone have such a thing.) I figured a set of short legs on the end on et engine mount bar would be spread far enough apart to be fairly stable. As for the rear, I hadn't got that far in my thinking. What I really wondered if how well it would start and run with no exhaust? I have a 1.8 and a 2.0 that are supposedly complete and want o make sure they actually run before putting one in the car. Each has full factory EFI (D-Jet and L-Jet). I also have an extra relay board, starter, etc. Might be easier to just use the car as the test rig.....you will have to switch the chassis mounted FI components to suit the L jet or Djet though. |
Lo-Fi Version | Time is now: 29th April 2024 - 01:49 PM |
