Clutch Tube Repair, How to do it? |
914 |
Mar 18 2017, 08:20 PM
Senior Member Group: Members Posts: 449 Joined: 26-December 02 Member No.: 19 Region Association: Southern California |
When I depress the clutch I here a clicking in the tunnel..The cable is maxed out with spacer nuts at the transmission end..What is the easiest way to do it as not to cut into the tunnel or weld..Is there a way?
Thanks,914 |
914 |
Mar 18 2017, 08:37 PM
JeffBowlsby |
Mar 18 2017, 08:43 PM
914 Wiring Harnesses Group: Members Posts: 8,477 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Search on the term "clutch tube repair", you should get multiple threads here.
porschetub |
Mar 18 2017, 08:45 PM
The Terry cable appears to have a bad rep (IMG:style_emoticons/default/confused24.gif) ,have you adjusted the clevis right up at the pedal,mine required cutting back by 12mm with all area's rebuilt,is your clutch worn,has the nylon ball in the throwout arm collapsed etc ,all that sort of stuff.
914 |
Mar 18 2017, 08:49 PM
914 |
Mar 18 2017, 08:51 PM
The clutch is nearly new..
Thanks.. The Terry cable appears to have a bad rep (IMG:style_emoticons/default/confused24.gif) ,have you adjusted the clevis right up at the pedal,mine required cutting back by 12mm with all area's rebuilt,is your clutch worn,has the nylon ball in the throwout arm collapsed etc ,all that sort of stuff. |
JeffBowlsby |
Mar 18 2017, 09:54 PM
Like I said, search on "clutch tube repair". Include the quotes and you will get multiple threads where this has been discussed forever.
burton73 |
Mar 18 2017, 09:56 PM
burton73 Group: Members Posts: 3,493 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
The clutch is nearly new.. Thanks.. The Terry cable appears to have a bad rep (IMG:style_emoticons/default/confused24.gif) ,have you adjusted the clevis right up at the pedal,mine required cutting back by 12mm with all area's rebuilt,is your clutch worn,has the nylon ball in the throwout arm collapsed etc ,all that sort of stuff. My 6 had a problem with this. The click of death. The PO put a U clamp to fix it toward the firewall. Take out the center tray between the seats and remove the cover and have someone push the clutch and take a look. You will see if it has broken lose back there. There are pictures on line showing where the Clutch tube is welded to the center tunnel where the shifter and wires, and gas lines go. Some guys get creative with clamps but there is only one great way to fix it right. You have to go in deep and weld. After removing the gas lines Bob |
Mar 18 2017, 10:14 PM
If only the front is loose, you can drill into the side of the tunnel (forward of the shifter) and plug weld the bracket onto the tunnel again. McMark did that to my car.
--DD |
burton73 |
Mar 18 2017, 10:19 PM
If only the front is loose, you can drill into the side of the tunnel (forward of the shifter) and plug weld the bracket onto the tunnel again. McMark did that to my car. --DD My 6 also had a u clamp there as well. U Clamp with 2 nuts tightening it on the left face of tunnel Bob |
sixaddict |
Mar 19 2017, 03:17 AM
Senior Member Group: Members Posts: 797 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Jeff
Could you please walk me though search procedure basics as I am truly (IMG:style_emoticons/default/confused24.gif) Thanks Search on the term "clutch tube repair", you should get multiple threads here. |
sixaddict |
Mar 19 2017, 07:17 AM
I found them...finally figured search was google but I thought you meant this site.
It turned out to be on this site but found it through a google search. Like the idea of accessing through the bottom for track car that may be best .....Headed to the local 914 wizard ... Oh mine was diagnosed as bad pressure plate but getting ready to install new one but old looks just fine ...KA---CHING ! Search on the term "clutch tube repair", you should get multiple threads here. |
mgphoto |
Mar 19 2017, 08:45 AM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
This repair can be avoided with the correct adjustment of the cable clevis, pedal stop and often overlooked thoughout bearing lever pivot ball, which needs to be repositioned to keep the mechanism within mechanical limits, when flywheel resurfacing is done.
Mike |
914 |
Mar 19 2017, 09:35 AM
Thanks everyone for the reply's.. I think now I have to remove the center console shifter to see what is really going on as for welding that one delicate area I prefer to use a clamp any more ideas..
Thanks,914 |
JeffBowlsby |
Mar 19 2017, 09:36 AM
Use the search function on this site...Google may get you there but its easier here.
A broken clutch tube cannot be adjusted around, it needs to be repaired. Attached image(s) |
914 |
Mar 19 2017, 11:08 AM
Jeff,
Can you arrow the spots at the tube is welded to.. I think i see them But your the Expert.. Thanks,914 Use the search function on this site...Google may get you there but its easier here. A broken clutch tube cannot be adjusted around, it needs to be repaired. |
djway |
Mar 19 2017, 02:13 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
The very front, that big oval piece and the rear. I added another support at the back end of the support for the throttle cable. I also added some extra material to that large oval piece. Mine was broken at the two forward supports.
eyesright |
Mar 19 2017, 04:57 PM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
When I depress the clutch I here a clicking in the tunnel..The cable is maxed out with spacer nuts at the transmission end..What is the easiest way to do it as not to cut into the tunnel or weld..Is there a way? Thanks,914 http://www.914world.com/bbs2/index.php?sho...=298186&hl= Here's my solution. If its what you need, PM me with your address and I'll send you one of my leftover prototypes to start you off. |
burton73 |
Mar 19 2017, 06:37 PM
Jeff, Can you arrow the spots at the tube is welded to.. I think i see them But your the Expert.. Thanks,914 Use the search function on this site...Google may get you there but its easier here. A broken clutch tube cannot be adjusted around, it needs to be repaired. This picture is the tunnel puled out of the car. It is like you are looking up from the bottom. I marked the spots where it is welded and my car was also welded at the firewall. If you look at postings you will see that the other tubes are for heater controls and Throttle. So I think when the clutch is pushed the cable makes the tube bend or flex. This makes it necessary for more nuts or washers on it as spacers. As I said my 6 was fixed with a U clamp and nuts. One by the driver’s right foot going towards the passengers side and one on the center floor wrapped over the tube as a clamp. U was going towards the ground with nuts on the threads to hold it. I guess that is a low cost temporary fix for guys back in the 80s. The repairs where removed and done right. The welding of the tube must have a screwdriver in the front of tube as a heat sink so you do not burn through the tube. Same in the back of the firewall. Just pull after the welding. I pulled the junk and I fixed it right and put a new floor section. Bob |
porschetub |
Mar 19 2017, 10:50 PM
This repair can be avoided with the correct adjustment of the cable clevis, pedal stop and often overlooked thoughout bearing lever pivot ball, which needs to be repositioned to keep the mechanism within mechanical limits, when flywheel resurfacing is done. Mike Yep said that. |
Lo-Fi Version | Time is now: 24th April 2024 - 05:49 PM |
