Clutch Tube Repair, How to do it? |
mgphoto |
Mar 20 2017, 06:11 PM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
The Terry cable appears to have a bad rep (IMG:style_emoticons/default/confused24.gif) ,have you adjusted the clevis right up at the pedal,mine required cutting back by 12mm with all area's rebuilt,is your clutch worn,has the nylon ball in the throwout arm collapsed etc ,all that sort of stuff. The cup is nylon, the ball is steel, there is 1 washer under the ball in stock config, adding additional washer under the pivot ball offsets the mechanism. If not the mechanism will pull against a solid structure causing the weakest point to give way ie the sheetmetal. |
914 |
Mar 23 2017, 08:08 PM
Senior Member Group: Members Posts: 449 Joined: 26-December 02 Member No.: 19 Region Association: Southern California |
Thanks for all the reply's in the shop now..
I will let you know the outcome.. Thanks 914 |
burton73 |
Mar 23 2017, 08:22 PM
burton73 Group: Members Posts: 3,493 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Thanks for all the reply's in the shop now.. I will let you know the outcome.. Thanks 914 Alan, What where the chances that a great bud lived just a few blocks from me with 2 914s in the same colors as 2 of mine. We both have a 1970 -6 in yellow and a 4. Sorry that my lift would not fit in your garage. Bob B |
Lo-Fi Version | Time is now: 24th April 2024 - 10:22 PM |
