remove air cleaner housing, how to? |
theleschyouknow |
Mar 19 2017, 11:19 AM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
hi all
stock 73 2.0 looking to fix a no start after 2 years (sad) sitting for other stuff going thru some fuel delivery checks how does the air cleaner housing come off? looks like some rubber cone-shaped plugs hold it to a runner attached (somehow) to the grey intake tubes on driver side it's tough to see in there/under there so I can't tell what needs what i've tried search, haynes and clymers and dicking around with it on my own what am i missing? TIA (IMG:style_emoticons/default/beerchug.gif) cjl |
Dave_Darling |
Mar 19 2017, 01:32 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Look at the metal spring clips that hold the top part of the cleaner onto the bottom. There are two more of that type of clip in the middle (left-to-right) down near the bottom of the lower housing. Those two clips hold the bottom half of the housing onto the bracket on the driver's side runner pipes.
Reach down and you should be able to feel the forward one. The rear is more difficult as access is pretty tight between the housing and the rear of the engine bay, but if you work you can get your hand down there. --DD |
theleschyouknow |
Mar 19 2017, 02:36 PM
thanks dave. will give it a go
(IMG:style_emoticons/default/beerchug.gif) cjl well that was easy thanks! cjl |
Lo-Fi Version | Time is now: 19th May 2024 - 11:57 PM |
