Anyone else tried a redneck AC in a 914?, hope my terminology doesn't offend anyone |
michael7810 |
Mar 20 2017, 01:22 PM
Senior Member Group: Members Posts: 1,078 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I will be driving my 914 from Phoenix to WCR in June without AC. It will be 100F+ across the desert anytime the sun is up and 90F+ at night. Since the passenger seat will be empty I decided to make a foam cooler AC unit (aka redneck AC) to help on the drive. There are many youtube videos and they are all basically the same. Cut 2 holes in the top of a foam ice chest; stick a fan in 1 and a PVC nozzle on the other. Fill the chest with ice, turn the fan on and enjoy the coolness.
I had an old tower PC fan and the foam cooler and PVC cost about $10. It was 95F on Saturday so I let the car sit in the sun for a while, inside temp was 101F, loaded the RNAC unit with 30 lb of ice and went for a drive. I didn't check the outlet air temp but it was slightly cool at best. While traveling north the inside temp dropped to 94F after about 25 miles on the highway which was still uncomfortable but with the slightly cool air blowing on my face it felt doable. Holy crap, when I turned south to head home and the sun was on the windshield (original glass with zero tint/UV protection) the inside temp jumped back up to 101F and after a while I thru up the white flag and rolled the windows down. Temp with the windows down was a pleasant 97F. After many hours of R&D while measuring the outlet temp I found that adding a second outlet hole gained a -2F improvement. I then moved the 2nd outlet close to the fan inlet to allow some recirculation and got another -2F improvement (-4F total). I put a 2nd fan inside the cooler to stir up the air inside but that did not reduce the outlet temp; neither did adding additional outlet holes or a second fan. I got another -3F improvement by adding a piece of pipe on the outlet hole inside the cooler to pick up the air closer to the ice...so now I'm at around 7F lower outlet temp and ready for another test drive. My wife thinks I'm a total idiot for even thinking about driving my car across the desert in June and even more so once she looked at the contraption in the passenger footwell. I commented that she didn't have to worry about me picking up anyone along the way since there's no room beside the 40 Qt ice chest, to which she replied she never worries about me picking up anyone while driving my 914 even when the passenger seat available...ouch. Any other ideas or experience out there? Is my wife right? |
dlkawashima |
Mar 20 2017, 03:08 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
I used a FlexiFreeze Ice Vest with an extra set of blue ice packs to use on a trip. Temps were in the mid-90's through some sections of the trip but I was fine. The first set of packs lasted about 60-90 minutes, somewhere in that range. The second set (the blue ice packs), even though I had stored them in a cooler, lasted only about 30 minutes. So I was able to stay cool for about 1-1/2 to 2 hours. Not bad, but then there's the problem of how to refreeze them.
One thing that might work with this method is buying bulk crushed ice along the way and putting the ice in extra large ziploc freezer bags. The vest has 3 large pockets where the freeze packs go, so I would think the freezer bags could act as a decent substitute (might not be very comfortable on your back, however). (IMG:http://www.914world.com/bbs2/uploads_offsite/images-na.ssl-images-amazon.com-12234-1490044122.1.jpg) |
Lo-Fi Version | Time is now: 18th April 2024 - 09:11 PM |
