Anyone else tried a redneck AC in a 914?, hope my terminology doesn't offend anyone |
michael7810 |
Mar 20 2017, 01:22 PM
Senior Member Group: Members Posts: 1,078 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I will be driving my 914 from Phoenix to WCR in June without AC. It will be 100F+ across the desert anytime the sun is up and 90F+ at night. Since the passenger seat will be empty I decided to make a foam cooler AC unit (aka redneck AC) to help on the drive. There are many youtube videos and they are all basically the same. Cut 2 holes in the top of a foam ice chest; stick a fan in 1 and a PVC nozzle on the other. Fill the chest with ice, turn the fan on and enjoy the coolness.
I had an old tower PC fan and the foam cooler and PVC cost about $10. It was 95F on Saturday so I let the car sit in the sun for a while, inside temp was 101F, loaded the RNAC unit with 30 lb of ice and went for a drive. I didn't check the outlet air temp but it was slightly cool at best. While traveling north the inside temp dropped to 94F after about 25 miles on the highway which was still uncomfortable but with the slightly cool air blowing on my face it felt doable. Holy crap, when I turned south to head home and the sun was on the windshield (original glass with zero tint/UV protection) the inside temp jumped back up to 101F and after a while I thru up the white flag and rolled the windows down. Temp with the windows down was a pleasant 97F. After many hours of R&D while measuring the outlet temp I found that adding a second outlet hole gained a -2F improvement. I then moved the 2nd outlet close to the fan inlet to allow some recirculation and got another -2F improvement (-4F total). I put a 2nd fan inside the cooler to stir up the air inside but that did not reduce the outlet temp; neither did adding additional outlet holes or a second fan. I got another -3F improvement by adding a piece of pipe on the outlet hole inside the cooler to pick up the air closer to the ice...so now I'm at around 7F lower outlet temp and ready for another test drive. My wife thinks I'm a total idiot for even thinking about driving my car across the desert in June and even more so once she looked at the contraption in the passenger footwell. I commented that she didn't have to worry about me picking up anyone along the way since there's no room beside the 40 Qt ice chest, to which she replied she never worries about me picking up anyone while driving my 914 even when the passenger seat available...ouch. Any other ideas or experience out there? Is my wife right? |
Elliot Cannon |
Mar 23 2017, 12:45 AM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
The Bkool unit works about 1 1/2 to 2 hours. You can carry extra ice in the front trunk (if you have one) to replenish the ice you have already used. This is actually a pretty good system and yes, pilots use it primarily for take off and landing or any time they are on the ground in a hot climate. You can turn it off when at altitude because it is usually much cooler once you are in the air. I used a home made system not unlike the Bkool system and I could get about an hour of really cool air with a much less efficient system with a much smaller ice chest. The limiting factor is how much ice you can carry. I think it has a great potential and I might try the Bkool myself this summer.
michael7810 |
Mar 23 2017, 04:46 PM
The Bkool unit works about 1 1/2 to 2 hours. You can carry extra ice in the front trunk (if you have one) to replenish the ice you have already used. This is actually a pretty good system and yes, pilots use it primarily for take off and landing or any time they are on the ground in a hot climate. You can turn it off when at altitude because it is usually much cooler once you are in the air. I used a home made system not unlike the Bkool system and I could get about an hour of really cool air with a much less efficient system with a much smaller ice chest. The limiting factor is how much ice you can carry. I think it has a great potential and I might try the Bkool myself this summer. Elliot - now you're REALLY not helping me. I called Bkool today and talked to Bob (Bob is Bkool) for about 30 minutes. The only reason I did not order one right there was I was walking the dog and didn't have my wallet. Seriously he seems like a great guy to deal with. He is also a long-time Porsche owner, currently driving a Macan. He said it will work great in a car as long as it's blowing directly on you and you don't mind stopping every 2 hours for ice. I don't mind frequent stops and in a 914 it would be hard to not have the air blowing on me. He said block ice lasts 2 hours and cubed or crushed lasts an hour and a half. I'm leaning towards the Bkool versus messing around with a homemade contraption. The high in Phx was only 69F today so AC is not a priority. (IMG:style_emoticons/default/beer3.gif) |
Lo-Fi Version | Time is now: 19th April 2024 - 07:31 AM |
